Need some advice on a K&N Cold Air
Old Mar 25, 2008 | 06:22 AM
reefdiver550's Avatar
reefdiver550 is a jewel in the roughreefdiver550 is a jewel in the roughreefdiver550 is a jewel in the rough
Do these get wet? I see they sit right under the opening of the latch...
Old Mar 25, 2008 | 07:00 AM
AllBusinessJoe's Avatar
AllBusinessJoe is infamous around these parts
Originally Posted by vividracing
The oiling nightmares you here are from users OVER oiling. K&N has done several tests and written an article on their site proving this MAF issue not being related when using the reoil procedure correctly. .
I recently purchased K&N intake from you and intend to install it later this week. (Thank you)
The question I have is with regard to the filter coming pre-oiled. My filter came sealed in plastic and does not look, smell, or feel as if any oil has been applied to the filter. Also, there is no oil residue on the inside of the plastic wrapper.
Is this as it should be, or should I apply oil to the filter?
Thanks in advance,
Joe
Old Mar 25, 2008 | 07:19 AM
swift996's Avatar
swift996 is infamous around these parts
Doesn't K&N supply a water repelling cover for the filter now? I have one on my RX8.
Old Mar 25, 2008 | 09:06 AM
vividracing's Avatar
just take the plastic packaging off and install it. dont add or do anything. they get no more wet then your stock air box. so dont worry. you would have to submerge the filter in water and then floor it to suck any damaging water into your engine. If it was an issue, K&N would not make them.
danyoP4S
Sep 30, 2021 05:06 AM
Paintballzen
Oct 10, 2020 12:22 PM
oo7
Sep 10, 2015 08:08 AM
