Help - Car Wont Start
Old Apr 16, 2008 | 05:02 PM
996CABOVA's Avatar
996CABOVA is a jewel in the rough996CABOVA is a jewel in the rough996CABOVA is a jewel in the rough
Hey guys. Im trying to search and im the LEAST car oriented guy out there. I went out to my car to start it and it wont start. It studders and hearing a tick tick sound from the engine. Also my trip mileage was reset to 0, and my clock went to 12 00. The windows act like they want to go down. Its weird I have no idea what it is. Could someone at least give me a lead, I had it out Mon w no problems and no CEL. Thanks
Old Apr 16, 2008 | 05:20 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
Absolutely sounds like a dead battery. These cars are not easy to jump start. If you try, there are two places to connect the chargers to-the battery itself and on the engine you will see a connection with a "+" sign - put the negative on the part of the latch attached to the body. Lastly, if this is the case, try Pep Boys or Autozone for a replacement. A lot less than the dealer. Bring your old battery to make sure that it is a perfect match. Good luck....
Old Apr 16, 2008 | 05:24 PM
wlee69's Avatar
wlee69 is infamous around these parts
Yup - sounds like a battery on its last leg. If there is still some juice you'll be able to pop the hood open...if the battery is totally dead, then you gotta go to the fuse and pull out the + terminal from there and charge enough so that you can pop to hood
Old Apr 16, 2008 | 05:30 PM
DaveMo's Avatar
Depending upon the year, there should be a cable inside the front fender when you open the passenger door. You should be able to pull it and open the hood.
Old Apr 16, 2008 | 05:42 PM
996CABOVA's Avatar
Yup I just jump started it and its the battery. Now i gotta figure out how to get another one at this time of night. Is it a Porsche battery you have to get? I have a convertible so dont know if I need a special type of battery
Old Apr 16, 2008 | 05:58 PM
daytrader's Avatar
daytrader is infamous around these parts
You can grap a new battery from Autozone. Make sure to get the same or higher cold crank amp. They open late. Actually, I don't even no where you live.
Old Apr 16, 2008 | 05:59 PM
daytrader's Avatar
Mine is a cab too. I use Duralast from Autozone for years with all my babies. Average life for my cars is 4 yrs.
Old Apr 16, 2008 | 06:38 PM
996CABOVA's Avatar
well i called AAA and they are coming to put a new one in the car. I dont know what kind they are putting in but it cant be worse than my DEAD one i hope
Old Apr 16, 2008 | 09:44 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
That blows, never happens at a convenient time does it? lol
You know what's funny, my manual hood latch cable is underneath the passenger's side headlight. How useless is that????
Old Apr 16, 2008 | 10:32 PM
judgejon's Avatar
judgejon has a spectacular aura aboutjudgejon has a spectacular aura about
been there, done that, got the dead battery t-shirt. happened to me the day after a long fun run. in fact, the alternator died, the voltmeter showed severe battery drain, and I barely limped into the garage before everything shut down. the battery was so dead it would not hold a charge, and when it was jumped from a towtruck all of the electronics on the car started acting like the car was on lsd. even the spoiler deployed with the car dead in the garage. a new battery and alternator did the trick. re the battery, I've used Interstate for years and like them. the battery I replaced was a Napa, and probably put in by the previous owner of the car. good luck...
Old Apr 17, 2008 | 07:47 AM
Steve Germany's Avatar
Steve Germany is infamous around these parts
If you Jump start it you stand a chance of blowing the two fuses for the radio/amp. You have to remove the head unit to get to one of them!
pwdrhound
Sep 16, 2021 02:27 PM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
vr6tee
Aug 29, 2015 03:52 AM
gulf gt
Aug 27, 2015 10:27 AM
DSCOFF
Aug 23, 2015 01:22 PM
