Worn Engine Mounts.
Old Apr 30, 2008 | 03:21 PM
Curves4S's Avatar
Curves4S is infamous around these parts
Worn Engine Mounts.
Has this happened to anyone? Began to notice a coolant leak from my car so I bought the necessary hose and replaced the reservoir cap. Then I noticed the leak coming from higher in the cooling system a part I couldn't get to.
Had the BH service center take a look and they said the engine was sagging on to the larger coolant hose due to worn engine mounts.
Does this sound familiar to anyone? is this normal? could this have something to do with taking turns hard and having a very steep drive way?? normal wear & tear?
Any input would be appreciated.
Old May 1, 2008 | 09:15 AM
c2mojo's Avatar
c2mojo is infamous around these parts
Ouch! Cheap parts but a ton in labor.
I don't think driving would do it, perhaps hard loads from shifting and aggressive downshifts over time.
I'd get polyurethane replacements while you are at it. Try www.fvd.us
Old May 1, 2008 | 09:27 AM
daytrader's Avatar
daytrader is infamous around these parts
Not the cap, not the hoses! Did you check the tank itself? Where does the coolant leak down on the ground?
Old May 1, 2008 | 10:04 AM
icemann633's Avatar
icemann633 is infamous around these parts
My engine mounts have worn....They are liquid filled so I guess it's appropriate.
I havent had any coolant issues though?
Old May 1, 2008 | 10:13 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
RS Motor mounts.
FVD = $686
Carnewal = $455
tough choice.
Old May 1, 2008 | 10:39 AM
Curves4S's Avatar
It was a different hose in the plumbing. Good thing it wasn't the reservoir otherwise that would be a lot in labor!
Old May 1, 2008 | 10:40 AM
Curves4S's Avatar
Thanks.. I had them replace them with factory parts... Can't wait to see what they rape me for.....
Jul 29, 2019 11:13 AM
speedsterr
Merchandise For Sale / Wanted
Nov 21, 2015 11:20 AM
pwdrhound
Aug 23, 2015 07:36 PM
pwdrhound
Aug 20, 2015 05:54 AM
