Supercharger Boost Gauge Help
For all those supercharged, Do any use a boost gauge? if so where have you installed your boost gauge. I want to keep the factory look so I'll be using the sport chrono pod for mine. I don't have the chrono option so, I'll just buy a chrono pod and try to make it work. Does the dash have the cutout lines for the sport chrono already? Has anyone done this Before? I need some help before I start cutting my dashboard. What boost gauge do guys you have or recommend? I have a 997 but it seems more 996s are Sc'ed than 997s, so i'm sure I'd get more help from the 996 guys An extra water temp meter would be good to make sure your Ic pump was still working or if you've sprung a coolant leak.
Many use Zeitronix ZT-2 which is capable of picking up A/F. EGT also. I have dicided not to use a visual which under boost is not visually acturate and just use the logging feature function instead and review on laptop when neccesary. My 2 cents. DDog uses it this way.
http://www.zeitronix.com/
Also look at the LM1 by Innovative. I had this in a 500hp BMW and loved it. Kept it when I sold the car and am probably going to stick it in the Porsche in the coming weeks. You can daisy-chain a slew of monitors and I personally think it is at the upper food chain for its accuracy.
http://www.innovatemotorsports.com/x...9e9ec9e94d416e
Oct 2, 2015 02:23 PM
smac
Sep 26, 2015 05:55 PM
ECS Tuning - VW
Sep 25, 2015 02:22 PM
