too much motor oil
Old Jul 28, 2004 | 10:06 AM
hanmike's Avatar
hanmike is infamous around these parts
Question too much motor oil
the dip stick was showing tha the oil was running low. So, I decided to add some but I added too much. Is this going to cause some problems? Should I take it in and get the oil changed? pleas help!
Old Jul 28, 2004 | 10:34 AM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
Take it in and drain some, to be on the safe side.
Old Jul 28, 2004 | 11:28 AM
joecmess's Avatar
joecmess is infamous around these parts
Recheck at normal temp,
Check the oil fom the dipstick when your car is at normal warm temperature. Shut it off, wait 5 minutes or so. That will give you the most accurate reading. If it is cold, all the oil will be in the pan, and will appear like there is too much.
Old Jul 29, 2004 | 03:29 AM
Marc's Avatar
Marc is just really niceMarc is just really niceMarc is just really niceMarc is just really niceMarc is just really nice
THE GAUGE
ON THE DASH REPRESENTS 1.5 QTS IF YOU WERE ALMOST TO THE BOTTOM LINE AND ADDED 1-2 QTS YOU WILL BE FINE AS WELL I ALWAYS CHECK THE DIPSTICK, IF YOU WENT A LITTLE OVER IT WILL BURN OFF IF YOU WENT ALOT OVER THEN GOTO THE DEALER AND DO AN OIL CHANGE, I PERSONALLY DID THIS AND CALLED CHAMPION AND THEY TOLD ME IT WAS NOTHING TO RUN THERE ABOUT...
Old Jul 29, 2004 | 04:58 AM
jnx's Avatar
jnx
jnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to beholdjnx is a splendid one to behold
Depends on how much you overfilled it. If you put way too much in, Drain some at home, before driving. You can do some serious damage with too much oil.
Old Jul 29, 2004 | 06:39 AM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
Just remember to only open the drain plug a tiny bit or you'll have a pretty serious mess on your hands. Don't ask me how I know
Old Jul 29, 2004 | 07:34 AM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
I've been told that it is easier to drain if you take it from the filter instead of the plug, which can quickly turn into Niagra Falls....
Old Jul 30, 2004 | 06:06 AM
jnx's Avatar
jnx
Get a topsider and drain from the dipstick tube. Very easy
Old Aug 19, 2004 | 11:31 AM
stanmo's Avatar
stanmo is infamous around these parts
For a car with a 2004 3.6L engine, is it 8.25L of oil? Thanks.
Old Aug 19, 2004 | 11:27 PM
LVDell's Avatar
LVDell is infamous around these parts
I use one of these for my MB and would use in a heartbeat to extract a bit out of the 996. Though I would never do an oil change with it on the 996, it is perfect for this application.
Extremely easy to use...And it's on sale!
http://www.thetoolwarehouse.net/shop/MIT-7201.html
Old Aug 19, 2004 | 11:48 PM
Tool Pants's Avatar
Tool Pants is infamous around these parts
If it is a quart or less do not worry about it. If it bothers you then unsrew the black plastic oil filter cannister. Oil will not pour out. You can dump the oil out of the cannister.
Old Aug 20, 2004 | 03:03 AM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Thanks! Been looking for this type for awhile. Great price too.
Old Aug 20, 2004 | 03:04 AM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
Hee Hee.... Boy do you know.... LOL
How are you doing Andy?
ricks234
Sep 10, 2015 12:51 PM
ECS Tuning - VW
Sep 8, 2015 01:34 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
