Need Help!!! I need to open the front trunk, but the battery isn't connected.
Old Sep 28, 2008 | 04:26 AM
pearl_porsche's Avatar
pearl_porsche is infamous around these parts
Hi everyone,
I need help to open up the front trunk. My friend disconnected the battery and I close the front trunk. My 996 is 2001, so the trunk opener is electric powered. Is there any way I can open it? Does anyone know how to open it? Can't connect the battery.... Heeeeeeeeelp.
Old Sep 28, 2008 | 06:31 AM
jstrat85's Avatar
jstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to all
Originally Posted by pearl_porsche
Hi everyone,
on the right side of the wheel well there is a metal wire that you can pull and it should pop open.
Old Sep 28, 2008 | 10:33 PM
my996's Avatar
1999 C4 Cab 6 Speed
my996 is infamous around these parts
If the metal wire way does not work, try this. In the engine bay, there is a terminal that powers the car as if the battery was there. It's used to give the battery a jump from the engine compartment. You can connect jumper cables to it and ground- then open your car. I did the same thing and this worked. Looked it up over on Renntech.org. Damn dealer tried to convince me to pay them $400 so they could dismantle the lock and get in that way. Good luck.
Old Sep 29, 2008 | 08:25 AM
Thanks guys, I'll try!!!
Old Nov 27, 2008 | 02:56 PM
ccmagic's Avatar
ccmagic is infamous around these parts
There are also a couple of terminal connections in the driver-side door jam that is designed for this exact situation. It's mentioned in the owner's manual.Good luck.
Old Nov 27, 2008 | 07:25 PM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
Open the fuse box and there is a pull-out terminal. Use a battery charger and connect the positive to the pull-out terminal and the negitive to the door latch/striker plate.
Old Nov 27, 2008 | 08:20 PM
DeAd-EyE's Avatar
DeAd-EyE is infamous around these parts
also, if ur booster pack came with a cigarette adaptor you can get power thru there...just plug it in and turn on ur booster pack. then unlock ur doors as normal.
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
