need help about diy air injection valve replacement
Old Oct 12, 2008 | 04:02 AM
SKY213's Avatar
SKY213 is infamous around these parts
thanks for everyone. i getting a check engine light with a diagnostic code of P0410 (Secondary air injection system) but alredy changed the air injection valve and SAI also reset the check engine light. But the engine light still come up. Do you guys think I'm missing something?
THANKS for your help
Old Oct 12, 2008 | 01:01 PM
Redridge's Avatar
so you changed #11 also?
Old Oct 12, 2008 | 01:48 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
A 410 code indicates an electrical problem. Check for signal at connections. Check fuse, relay, changeover valve triggger as well as if pump works when fed direct current.
Old Oct 12, 2008 | 04:31 PM
SKY213's Avatar
redridge thanks for you help i also changed #11 #1 #3 #5 but the check light
still come up
Old Oct 12, 2008 | 05:22 PM
Redridge's Avatar
wow, you changed #1... upon start up, can you verify that it has turned on? (It sounds like a vacuum cleaner, Open the hood and you can feel (vibration) that it is on. After a minute or so... it will shut off. If it doesnt... we'll have to go to the schematics.
Old Oct 12, 2008 | 06:25 PM
So, was it your idea or your mechanic's idea to just start replacing hundred of dollars in parts before diagniosing your problem? Sounds like a Porsche Technician. The SAI is a very simply system and each and every componant can be easily verified as to whether it is working or not. You say you changed the air pump. Have you confirmed it even works after installed?
Often, these codes are caused because the vacuum line from the vacuum reserve is not connected. It can also be an electrical problem with the changover valve, or a bad air changeover valve. The vacuum line for the electric changeover valve is so small that identifying it as a vacuum leak with a vacuum gauge is difficult. You codes indicate that both banks are experiencing probelms so it is probably a single, main componant.
Here is what I would do. Assuming that the pump is working.
With the engine running, remove the vacuum line for the electric changeover valve that goes to the vacuum reserve canister. There should be constant vacuum. If not, the other end of the hose is disconnected and your air changeover valve will not open.
Next, on a cold engine, remove the other vacuum line from the air changeover valve. Start the car, at which time the pump should start. You should be getting a vacuum in the disconnected line until the pump shuts off. If not,. problem is with the electric changeover valve.
On the other hand, you can immediately jump to the end and remove the larger hose from the non return valve. On a cold engine, the pump should start and there should be air blowing out of the hose. When the pump shuts off, the blowing will stop completely and NO AIR should be coming back out of the valve. If this is the case, then you can safely assume that everything before this point back to the pump is working as designed.
The function of the system is simple. There is constant vacuum to the electric change over valve to which a vaccum line to the air valve is connected. When off, the electric changeover valve does not allow vacuum to get to the air valve. When on, (pump running) the valve activates and allows vacuum to get to the air valve and allows air to pass into the manifold through the one way valve.
Old Oct 12, 2008 | 07:16 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
BTW just to help eliminate some causes, it could be both electrical or mechanical for this fault, the reading for secondary air pump operation comes from the oxygen sensors and is compared against a known value, this fault is for below value, so either there is a blockage or a valve not opening,and P0410 is bank 1 specific, so the eliminates a lot of the system, air pump,vacuum resevoir line connection,, make sure there isnt a piece of carbon or something stuck in 12 or in the connection to the head also.
Old Oct 25, 2008 | 01:55 AM
SKY213's Avatar
thanks for your help redridge. The problem is vacuum hose. now i fix up ready the light not come up again. thank you
Old Oct 25, 2008 | 01:56 AM
SKY213's Avatar
thank you porsche 917
Old Oct 25, 2008 | 02:00 AM
SKY213's Avatar
thanks for your help. 1999porsche911 no more problem now thanks!!!
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
The Oss
Aug 24, 2015 08:19 PM
Lucid Moment
Aug 20, 2015 02:22 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
