Rear Bumberett Removal: Best Way To Do?
Old Nov 25, 2008 | 08:13 AM
p944s1987's Avatar
p944s1987 is infamous around these parts
Hi,
As it is time in the Notheast to gargae the car, I want to have Bumber Plugs paint the two rear bumberetts on my '99 911 C4.
How is the best way to take these off the car and exactly what do I need????
Thanks guys.
Mike
Old Nov 25, 2008 | 05:05 PM
flash80's Avatar
flash80 is infamous around these parts
It's not that difficult. Underneath the bumperette there are plastic covers. Just use a small flathead screwdriver and pry them out. Then there is a bolt that holds the bumperette in place. It's hard to see without a flashlight. You have to use a long allen wrench to unscrew the bolt. I'm not sure what size it is--I will check. Loosen the bolt enough and you can lift up and the bumperette will unhook from the metal bracket.
Old Nov 25, 2008 | 10:37 PM
fotostars's Avatar
fotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud offotostars has much to be proud of
Yep, was about to say the same. I just did it last month.
You lay down behind your car with an allen head and an extender and you loosen the 2 screws (M8x25 I believe).
The bumperettes are 'hooked' on metal brackets. Very, very straight forward process...
Enjoy! It gives such a different look, you'll love them!
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
