Car not starting on the first crank
Old Dec 12, 2008 | 01:47 PM
JoeyM's Avatar
JoeyM is infamous around these parts
Originally Posted by djhill
I'll bet it's the clutch switch.
+1.
although i had an audi that did that once in awhile. i kept messing with clutch switch and even bypassed it and to this day i'm not sure if that was it.
it was so sporadic i never was able to figure it out.
i even had to pop start the car a couple of times. then it went away, and never came back.
Old Dec 12, 2008 | 02:18 PM
Mikke996's Avatar
Mikke996 is infamous around these parts
Mine was not starting and it was the transponder in the key.
Try a different key?
Regards Mika
Old Dec 12, 2008 | 03:03 PM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
my key is out of battery lol
i unlock the door manually
Old Dec 13, 2008 | 08:13 AM
Benjamin Choi's Avatar
Benjamin Choi is infamous around these parts
guys, it's not the key for me.
Old Dec 15, 2008 | 09:13 PM
Exlondoner's Avatar
Exlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud ofExlondoner has much to be proud of
Mr Choi did you get this issue resolved?
Old Dec 16, 2008 | 09:20 AM
BMoney5327's Avatar
BMoney5327 is just really niceBMoney5327 is just really niceBMoney5327 is just really niceBMoney5327 is just really nice
Had the same problem yesturday,let it sit for about 20mins then tried it again and it turned on. But now my check engine light came on lastnight..Ehh
Old Dec 16, 2008 | 10:33 AM
not yet, bud. it was 19 degrees this morning and i attempted tos tart the car. same thing. 2nd try a few seconds later bam it starts like normal.
Old Dec 16, 2008 | 10:55 AM
angldrkns9's Avatar
yeah. mine still has the problem too
it makes sense if it's the clutch switch
Old Dec 16, 2008 | 12:53 PM
Brucem's Avatar
Senior Member
Brucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to all
Hey Ben, i had a similar issue on my car, when I did all the work this past summer I replaced the Starter Solenoid and it has worked perfect since. By how much you are driving the car right now it may be something you can live with till spring..
Merry Christmas to you and your family Ben!!
Old Dec 16, 2008 | 01:49 PM
thx bud, yea it's happening because my car's been sitting in the garage more often than usual. stay safe and happy
Old Dec 16, 2008 | 04:57 PM
kpl's Avatar
kpl
kpl is infamous around these parts
does it make any difference if you put the key in and immediate turn it to start the car, vs. put the key in - click it over only far enough to run the oil level check - then click it over to the next notch to start the car?
Old Dec 16, 2008 | 05:53 PM
don't matta
Old Dec 16, 2008 | 06:02 PM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
You just had it in the shop and all checked out OK. So, what did they have to say about this issue?
Let me guess.... "If we can't reproduce the problem, we can't diagnose it."
Old Dec 16, 2008 | 07:17 PM
Exlondoner's Avatar
hence my reply to this thread. Didn't you get them to sort that problem out me'ol chap
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
Sep 1, 2015 03:16 PM
DSCOFF
Aug 23, 2015 01:22 PM
Aug 20, 2015 12:17 PM
