Car not starting on the first crank
Old Dec 5, 2008 | 10:11 AM
Benjamin Choi's Avatar
Benjamin Choi is infamous around these parts
This morning, I get to the car, try to start the car and when I turn the key to crank the car, it doesn't do anything.
I try again and again and finally it starts like normal. The car's been sitting for a few days and I've been driving it a lot less.
Thoughts?
Old Dec 5, 2008 | 10:17 AM
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
Ignition switch intermittent???
Old Dec 5, 2008 | 01:49 PM
win911's Avatar
win911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud ofwin911 has much to be proud of
When you say it doesn't do anything.... I'm assuming the starter does not crank at all...right. Sound likes the ignition switch but check your battery terminals for corosion or loose terminals. That's easier than the ignition switch... Also your clutch starter switch if your car is a manual trans.
Good luck..
Old Dec 5, 2008 | 01:59 PM
yea it does nothing. no sound whatsoever. no cranking.
i'll check all those things. i take it this issue is not uncommon?
Old Dec 5, 2008 | 02:16 PM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
It is clearly an electrical issue. Either there is no juice from the battery or one of the switches mentioned is cutting it off. I agree those are your best three things to look into. Two other things to pay attention to...
I don't know if the ign switch is in the steering column. If so, try to jiggle the key in the cylinder to see if it makes the ignition switch catch.
Also, just make sure your floor mats are not hindering the full depression of the clutch pedal. I know you just had your clutch replaced. Maybe they got the pedal adjustment a little loose and now the switch is not fully activating.
Old Dec 5, 2008 | 02:19 PM
it's been several months of regular usage post clutch install. just started happening earlier this week and i only drove the car twice so far to work.
i'll check the mat but i doubt that's it. i have a feeling i'll have to put in a new switch. once it starts in the morning, not able to repeat the issue during the day.
Old Dec 5, 2008 | 02:49 PM
nine9six's Avatar
nine9six is infamous around these partsnine9six is infamous around these parts
Maybe you didn't press down the clutch enough?
I had that some thing happen then i realized I didnt press all the way down the clutch pedal.
Old Dec 5, 2008 | 02:57 PM
perhaps............ i'll be mindful of it
Old Dec 5, 2008 | 03:05 PM
Brando's Avatar
Brando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud of
Cool
You know....I have experienced the exact same thing....however, it happens randomly.
I was worried that maybe the starter solinoid was going out but it has not done it lately.
Old Dec 9, 2008 | 02:51 PM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
i have the same exact problem with my car. i haven't had the issue all summer but with the car sitting more and the colder weather, it seems to happen more often now.
i was suspecting i was't pressing the clutch pedal all the way down but i jam it all the way and it seems to have the same problem
Old Dec 9, 2008 | 04:09 PM
ls911's Avatar
ls911 has a spectacular aura aboutls911 has a spectacular aura aboutls911 has a spectacular aura about
Hey Ben
Next time this takes place try to turn the lights, radio and fan on and then try to crank it over.
This might help you out in trouble shooting it a bit more
If nothing works and it's time to part it out I'll like your wheels, SSK and seats pls.
Old Dec 9, 2008 | 04:16 PM
bruceinmiami's Avatar
bruceinmiami is infamous around these parts
happened yo me once, when car sat for 3 weeks. after a few tries it started no problem, and never repeated the symptom. my car only sees action about 1 or 2 times a week.
Old Dec 9, 2008 | 04:40 PM
yea, my car's def been sitting around more since it's busy season for me at work and the weather is in typical seattle mode now + it gets dark at like 4:30PM.
let's do each other a favor and keep each other posted on any fixes. my trusty dealer contact said just keep an eye out and if it gets bad, come in and they'll fix it.
i know it's not user error.
Old Dec 11, 2008 | 07:36 AM
2fas4u's Avatar
2fas4u is infamous around these parts
Wink permit please!
You need the ray gun, and don't shoot yourself in the thigh while @ a night club like an idiot!
Old Dec 11, 2008 | 05:50 PM
djhill's Avatar
djhill is infamous around these parts
I'll bet it's the clutch switch.
