Flat rear tire PITB
Old Jun 7, 2009 | 11:44 AM
brandon113's Avatar
Awaiting Email Confirmation
brandon113 is infamous around these parts
Flat rear tire PITB
Learned a lesson last night. Blew a rear tire last night, pulled over, got the tools out and could not loosen the lugs nuts as the lug wrench handle is really short. There was a Lowe's close so I went in a bought some black pipe to use as a cheater, worked, great got the tire off and the new little wimpy tire on. Went to put the tire in the trunk, uh no way won't fit. Hmmmm open the top and put it in the back seat Jezzz glad I had a blanket to cover it in....Lession it helps to have your 10 year old son in the back seat to hold the old tire when you have to change it and carry a 3 ft piece of pipe to help get the lug nuts off. or just call Porsche roadside assistance.
Brandon
Old Jun 7, 2009 | 07:55 PM
92tsiawd's Avatar
92tsiawd is infamous around these parts
glad to hear you got the lugs off. I usually carry a torque wrench in the trunk all the time, might be a good idea for you
Old Jun 7, 2009 | 09:07 PM
skizot's Avatar
skizot has much to be proud ofskizot has much to be proud ofskizot has much to be proud ofskizot has much to be proud ofskizot has much to be proud ofskizot has much to be proud ofskizot has much to be proud ofskizot has much to be proud ofskizot has much to be proud ofskizot has much to be proud of
I put together an emergency kit that has all sorts of extra tools and the sort in the trunk. If you do not have something like this, I would highly recommend it.
Old Jun 8, 2009 | 08:15 AM
perryinva's Avatar
perryinva is infamous around these parts
FWIW, (probably too late for you now, but maybe someone else will benefit, as the info in your post is very helpful as well ), but if you look in the manual, it tells you to only put the mini spare on the front, then move the front tire to the rear, and turn off PSM if you have it. Skizot, I'd be curious as to what emergency tools you carry.
Old Jun 8, 2009 | 10:33 PM
cap'sx51's Avatar
cap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant futurecap'sx51 has a brilliant future
Does it apply even if the wheels have different widths (Front vs Rears)? +1 on the emergency tools list. Thanks.
Old Jun 9, 2009 | 05:56 AM
deckman's Avatar
It must apply since Porsche ships different widths as stock on all 911's.
Old Jun 9, 2009 | 01:11 PM
perryinva's Avatar
I would say it's mainly because of the rear weight bias of the 911 and the fact that if you HAD to suddenly accelerate, the mini spare would probably shred from the torque.
oufan2929
Nov 8, 2015 08:26 PM
L.A.P.
Oct 19, 2015 10:01 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
L.A.P.
Aug 23, 2015 11:48 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
