Pedal Installation Help
Old Jul 2, 2009 | 11:38 AM
PierceZ's Avatar
PierceZ is infamous around these parts
I bought a pair of aftermarket aluminum Pedals that look just like the Porsche ones except they don't say Porsche. The pedals did not come with instructions, I've got the clutch on and I'm half way done with the brake (I broke a drill bit and had to go get one that is supposed to drill through metal) What I don't know how to do is the gas and foot rest. Does anyone have instruction or any tips?
Old Jul 2, 2009 | 12:23 PM
bjarne996's Avatar
bjarne996 is infamous around these parts
When I installed my alu pedals that replaced the pedal rubbers I used screws to fasten the break and clutch, while for the footrest and accelerator ones I simply cleaned and used double sided tape.
Doing it again I would have used silicone in addition to make sure they would not fall off even if a screw should break or the double sided tape should fail.
Old Jul 2, 2009 | 01:04 PM
Hamid996's Avatar
Hamid996 is infamous around these parts
Yep, I used heavy duty double sided tape, and removed existing rubber pedals to drill them in. The brake pedal is a pain. I broke a ton of bits getting into that one.
Old Jul 2, 2009 | 01:05 PM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
Odd, I had no troubles... drill pilot holes first.
A
Old Jul 2, 2009 | 01:57 PM
wross996TT's Avatar
have a look here...may depend on your make.
Old Jul 2, 2009 | 05:46 PM
scubadawg's Avatar
scubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to behold
Place a wood block, behind brake and clutch pedal, it supports the pedals, so they don't move when you drill them.
I also place masking tape on the pedals and marked them with a pen so I know to drill.
Last edited by scubadawg; Jul 2, 2009 at 05:47 PM. Reason: additional instructions
audipwr1
Sep 25, 2021 01:31 PM
cerbomark
Aug 22, 2015 12:50 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
