Track setup- X51 Oil Pan
Old Jul 30, 2009 | 06:54 AM
C70Pete's Avatar
C70Pete is infamous around these partsC70Pete is infamous around these partsC70Pete is infamous around these partsC70Pete is infamous around these parts
Originally Posted by steveespo
Pete
The one way valves are trap doors in the sump that surround the pick up. The oil can push the door "in" so the oil gets back to the pump pickup, the doors can't swing out during lateral acceleration because they have stop framing, so the oil can't "run" away from the pickup causing oil starvation, and accumalation in the cam boxes. Not as much as without I should say, with the flat six fluids will always centifuge out towards the direction of lateral 'g'.
Steve E.
Thx Steve,
isn't this what the X-51 pan does? the pan has trap doors all around that swing open only to let oil in and not out... are we talking about the same thing?
Old Jul 30, 2009 | 01:57 PM
TdiRacing's Avatar
TdiRacing is infamous around these parts
IS the X51 oil pump still available? The pump and the oil line for the conversion? There are some posts but the pumps were hard to find. There is a company in Germany that makes one as well, but it is 1000Euro's so really expensive as well....
I guess if you wanted to race the car, the oil pump conversion with the pan would be the better way to go...
Old Aug 2, 2009 | 01:03 AM
TdiRacing's Avatar
I guess I was a bit confused by all the information about the oil system issues of the 996 engine. In one of my previous posts I was asking about oil ingestion(which I guess is caused by the oil separating baffle), which causes the engines to smoke at the track under hard cornering, and in some cases actually has the potential to hydo-lock an engine. I guess there is a Porsche racing separator that can be fitted to help with this smoking issue. This is a separate issue to the oil starvation and oil pan discussion. Sorry if I sounded confused...I actually was
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
PV=nRT.
Sep 9, 2022 06:06 PM
HotRod
Sep 10, 2015 07:17 PM
Fester
Sep 8, 2015 09:35 AM
away
Sep 4, 2015 12:30 PM
