Oil correct level
Old Aug 7, 2009 | 11:39 AM
citybythebay's Avatar
citybythebay is infamous around these parts
Oil correct level
On my 99 Cab, it shows around 2-3 on the oil gauge when idling but when i check the dipstick after 5 minutes with the engine off, the level looks just fine. It's been about 2 years since the last oil change although i added just about 2k on the mileage. I don't want to put more if unnecessary...Any idea?
Old Aug 7, 2009 | 12:58 PM
asialors996's Avatar
asialors996 has a spectacular aura aboutasialors996 has a spectacular aura aboutasialors996 has a spectacular aura about
2 YEARS!!!! you should not leave the filter or the oil in the car that long....1 Year at the MAX!!! It Idle with thin oil 0-40 new...I usually get 2-3bar....once i step on the gas it jumps to 5
If the stick says your at the correct level after sitting for a while with the motor off then your fine...your in san farncisco...try a heaver oil 15-50 Mobil 1 or something around there its always hot where you are so the thinck oil will thin out anyway
Old Aug 7, 2009 | 07:00 PM
jeveretts's Avatar
jeveretts is infamous around these parts
Also be careful not to put too much in, My local shop put a little bit over, maybe a half quart, and a couple of times right after, when under full throttle, around 6K RPM in a wide sweeping curve. the engine sucked a little oil.. coughed down a bit and smoked out the pipes for a minute or so.. after doing this twice, I have had no more trouble.
nlakind
Nov 6, 2015 10:15 AM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
