HELP! "check failure" oil warning came on.. ???
Old Aug 9, 2009 | 07:01 PM
EB847's Avatar
EB847 is a jewel in the roughEB847 is a jewel in the roughEB847 is a jewel in the rough
ok, so driving my 02 c2 down the freeway.. the following popped up
(i believe anyway.. it went away quickly): "check failure" and the oil can symbol.
my oil pressure bounced from 5-1, then leveled off at just below 5. i pulled off freeway to restart, check oil level, etc. all was well. pressure was 2 at idle.
no check engine lights.. also, just had oil change. was able to drive, but oil pressure seemed to be high and fluctuated at frwy speeds from 4-5 at same rpm with cruise control on.
thank god for cpo... off to dealer in the am.
WTF? anyone else have anything like this happen?
Old Aug 9, 2009 | 08:54 PM
PorschePRH's Avatar
PorschePRH is a name known to allPorschePRH is a name known to allPorschePRH is a name known to allPorschePRH is a name known to allPorschePRH is a name known to allPorschePRH is a name known to all
I had that happen. I restarted and it's been fine since then (about 8 months ago).
Old Aug 9, 2009 | 10:34 PM
TraderJoe's Avatar
TraderJoe is infamous around these parts
Had the same issue. Just cleaned the wires from my oil sending unit thanks to a fellow 6speeder and haven't had any problems yet.
Old Aug 10, 2009 | 07:46 AM
YoopsRacing's Avatar
YoopsRacing is infamous around these parts
oil sending unit is failing or wires need cleaning
Old Aug 10, 2009 | 10:27 AM
EB847's Avatar
thx dudes, it's on the rack at the dealer. should be back on the road today after a cpo fix (god willing)
Old Aug 10, 2009 | 02:33 PM
EB847's Avatar
result: i need a new cluster for a faulty oil pressure guage. luckily it's cpo fix! engine is fine, no codes. whew!
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
Fester
Sep 8, 2015 09:35 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
