Detailed DIY Sound System Install With 50+ Photos
Old Dec 23, 2011 | 09:59 PM
  #31
Doug996InKC's Avatar
Doug996InKC is infamous around these partsDoug996InKC is infamous around these parts
photos 47-51
ID:	165834   Click image for larger version
ID:	165835   Click image for larger version
Old Dec 23, 2011 | 10:00 PM
  #32
photos 52-54
ID:	165839   Click image for larger version
Old Dec 24, 2011 | 01:17 AM
  #33
blazinkn1ght's Avatar
blazinkn1ght is infamous around these parts
WOW thanks doug for info.
how much would the 3 way system like yours would cost on average today?
Old Jan 7, 2012 | 12:16 PM
  #34
stephan79's Avatar
stephan79 is infamous around these parts
I have the following:
1) Kenwood DNX7100 Nav/Head Unit w/iPod
2) Three JL Audio 8" Subwoofers
3) JL Audio 500.5 Amp
4) JL Audio Evolution 4" in the dash
4) JL Audio Evolution 6.5" in the doors.
Old Jan 7, 2012 | 02:30 PM
  #35
Slider's Avatar
Here is the map to the OEM radio wiring. Look at the colours under the "Speaker" heading - ignore "shelf" and "sub" - I added those speakers.
Old Mar 26, 2013 | 12:34 PM
  #36
pfbz's Avatar
pfbz is a jewel in the roughpfbz is a jewel in the roughpfbz is a jewel in the rough
I realize this is a pretty old thread, but a bump for a really nicely done how-to thread...
I was searching for some ideas on amp mounting and wiring for my setup [ipad mini / pioneer head unit / polk speakers, documented here]
The only thing I'm not completely comfortable with is drilling the sheetmetal for the amp board. I'd much prefer to use factory bolt locations, but it doesn't seem like they are in good spots. If I do drill, I was thinking of installing rivnuts just in the sheet metal instead of through bolts. Would eliminate that grinding/sealing you had to do on your mounting bolts.
Thanks for the ideas and good documentation!
Old Mar 26, 2013 | 10:03 PM
  #37
white out's Avatar
white out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to behold
Where did you get the AMP mounting spacers?
Old Mar 27, 2013 | 07:40 PM
  #38
They are black rubber stoppers found at home improvement stores. Example: http://www.homedepot.com/p/t/1003386...7#.UVOfM1fux-Q
Old Mar 27, 2013 | 07:44 PM
  #39
Originally Posted by pfbz
...if I do drill, I was thinking of installing rivnuts just in the sheet metal instead of through bolts. Would eliminate that grinding/sealing you had to do on your mounting bolts.
Good call! I wish I would have known of such fasteners several years ago. I may just swap those out one day. Putting link here for future reference...
http://www.fastenal.com/web/search/p...et%20Nuts%22|~
BTW, congrats on your iPad mini install! Impressive!
Old Mar 27, 2013 | 08:21 PM
  #40
pfbz's Avatar
Thanks! It was fun putting the iPad in, but an additional amp is next on the list...
On the rivnuts (aka nutserts, threaded inserts, rivet nuts), I'd suggest aluminum ones for light duty applications like mounting an amp. The steel rivnuts need a much beefier (and much more expensive) tool to install properly.
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
karlfranz
Aug 19, 2015 09:05 PM
