Overfilled with oil my 2003 911 cabrio
Old Dec 3, 2009 | 06:14 PM
DAN TUCCI's Avatar
DAN TUCCI is infamous around these parts
Are there any other idiots out there like me who overfilled their oil ? Got about a quart to much in there ? Do i need to drain some out ?
Old Dec 3, 2009 | 06:19 PM
Jam996's Avatar
Jam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud of
Yes, oil level should not be exceeded!
drain some out.
Old Dec 3, 2009 | 06:55 PM
996c4s4dailyuse's Avatar
996c4s4dailyuse is infamous around these parts
yes you should have some drained overfilled oil can cause your plugs to build up carbon and will suck into the intake manifold
Old Dec 4, 2009 | 01:23 PM
JonC4S's Avatar
JonC4S is a splendid one to beholdJonC4S is a splendid one to beholdJonC4S is a splendid one to beholdJonC4S is a splendid one to beholdJonC4S is a splendid one to beholdJonC4S is a splendid one to behold
Yeah, even the dealers overfill sometimes. I bought an oil extractor to pull a little out of the dipstick tube when it happens. Easiest and lowest mess approach.
Old Dec 6, 2009 | 08:49 AM
jhbrennan's Avatar
I always ask the mechanic to leave the last quart with me and I top it up to "full". Lots of different ways to remove excess - I bought a plastic siphon hose at Pep Boys and removed excess that way. I've read other folks actually use the drain plug to let a little out - my fear with this method was that a little could become a lot. Good luck.
Old Dec 10, 2009 | 05:45 PM
porsche510's Avatar
porsche510 is infamous around these parts
Sorry I am dropping in on your thread: how can you tell when too much oil? I add oil half a quart now and then myself. There is a stick in the engine, I pull it out, can't tell if it's enough. Thanks
Old Dec 10, 2009 | 06:39 PM
uberpoop's Avatar
uberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond repute
porsche510- stick is a good way, but second option is put the key in ignition, turn to on but without starting. you should see a countdown in your gauges. at end of countdown it will show your oil level.
if countdown is like 10 minutes, just run car until engine is at operating temp, then do the key thing again.
Old Dec 10, 2009 | 07:29 PM
jhbrennan's Avatar
It's in your owner's manual - here's the page.
File Type: pdf
2lflat4
Nov 18, 2019 05:05 PM
CoreyC2S
Nov 18, 2017 12:13 PM
Enemy
Oct 24, 2015 04:14 PM
saline
Oct 7, 2015 07:29 AM
DaButcher
New Member Introductions
Sep 16, 2015 02:49 AM
