2002 C4S engine knock
Old Dec 23, 2009 | 07:57 PM
Sylvain's Avatar
Sylvain is infamous around these parts
Hi ,
I just bought my first Porsche a 2002 C4S .
When the engine is hot and I start the engine I ear a knock from the engine.
then after that it runs normally.
A friend of mine told me that's normal for a Porsche
Need your advice.
Thank you all
Sylvain
Old Dec 23, 2009 | 08:43 PM
rbuisa's Avatar
rbuisa is infamous around these parts
I have an '03 and don't have that problem. What exactly do you mean by knock? When does it happen.....when the engine first turns over? does it last for a few minutes then go away?
By chance did you have a PPI done before you bought the car?
Old Dec 23, 2009 | 08:50 PM
Sylvain's Avatar
thanks for your reply.
it only knock while I start the engine not more than that
thanks
Old Dec 23, 2009 | 08:59 PM
kirky's Avatar
kirky is infamous around these parts
I have a 02 c4s with 58k on the clock and I do not get this knock you mentioned. Can you try to pinpoint it a bit better. Does it only happen when the engine is hot and its restarted or does it happen on a first start of the day ?
Old Dec 23, 2009 | 09:20 PM
tw02996c4s's Avatar
tw02996c4s is infamous around these parts
Does it knock while you're turning the engine over or after it starts?
Old Dec 25, 2009 | 12:12 AM
Ahmet's Avatar
Ahmet is infamous around these parts
A bit of a "rattle" upon start up is OK -as the chain tensioners get oil pressure. I can't think of a knocking sound that'd be considered normal under any circumstances though...
Old Dec 25, 2009 | 12:56 AM
Sylvain's Avatar
thanks you for all your replies.
my engine knock while I start it only, not after , and only when the engine is hot.
As it's my first Porsche may be I think it's knocking an it's a normal vibration as another member talk to me here.
I will bring it to my local dealer
thank you again
Sylvain
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
vr6tee
Aug 29, 2015 03:52 AM
