X51 Problems
Old Feb 11, 2010 | 08:52 PM
Jiffen's Avatar
Jiffen is infamous around these parts
X51 Problems
I have a 2004 40th anniversary which comes with the X51 engine. The engine tends to buck when starting out at light throttle. Not an issue with more throttle. It seems to be running lean, on the threshold of stalling. Anyone heard of this?
Old Feb 12, 2010 | 03:33 PM
M3Armand's Avatar
M3Armand is infamous around these parts
I have an X51 in my 996. I don't have this issue (knock on wood). However, when I did the PPI on the car, I believe 2 spark plugs were loose. You might want to start there?
Old Feb 12, 2010 | 06:31 PM
djhill's Avatar
djhill is infamous around these parts
Mine does that once in a while too. I was considering starting a thread on this as well. I thank the bucking may be a result of not giving it enough gas as you release the clutch. Or could it be a sign of bad RMS? I replaced my RMS and clutch about 9k miles ago.
Old Feb 15, 2010 | 09:00 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Mine was doing this a few days ago. Even threw a check engine light. Dealer said it could be because of winter gas or I started the car with my foot on the gas. Well who knows. I got a check engine light the other day again so I add some fuel system cleaner with about 1/4 tank of gas left and then disconneted the pos battery terminal. Light went away and engine remapped the fuel settings. Running 1000% better now.
Old Feb 17, 2010 | 07:33 AM
Malakas's Avatar
Malakas is infamous around these parts
I was having similar problems (non X-51) and I needed new spark plugs and found that 2 coil packs were cracked. Per Porsche the plugs should be changed every 60K miles, OR 4 years... I had the original plugs, my car is a 2002. Much improved now.
cockneymike
Oct 22, 2015 06:00 PM
bhart192
Sep 28, 2015 10:37 AM
gadgetman
Sep 21, 2015 06:55 AM
vogz
Sep 19, 2015 01:02 PM
bhart192
Sep 7, 2015 03:17 PM
