Engine cover strut
Old Jun 16, 2010 | 09:46 PM
Harmony Jim's Avatar
Harmony Jim is infamous around these parts
Engine cover strut
My 2000 C2 cab engine lid will not stay open. The single strut used is obviously bad. Can they be rebuilt, and if not, where is the best place to find a replacement? It appears there may be mounting bosses for a second strut on the opposite side of the lid. Can two be installed? Same item as the right side strut? Thanks in advance.
Old Jun 16, 2010 | 10:21 PM
Sosoomi1's Avatar
Sosoomi1 is a jewel in the roughSosoomi1 is a jewel in the roughSosoomi1 is a jewel in the rough
I hope the picture uploaded, but I have 2 struts, perhaps that is your problem having only one... I would check out LA Porsche Dismantlers if I needed something like that!
Old Jun 17, 2010 | 08:46 AM
himself's Avatar
himself is a jewel in the roughhimself is a jewel in the roughhimself is a jewel in the rough
You might as well buy a new one. They are like $20. I looked up the part number, and it appears to be: 996 512 551 03.
Call Suncoast and find verify the part, and that you only need one (PET shows 2 for C4S, and 1 for C2). But I wouldn't rebuild a $20 part...
-td
Old Jun 17, 2010 | 09:51 AM
John L's Avatar
John L is infamous around these parts
+1 on buying a new set, they are cheap, I just replaced the two on my front lid, 2 minutes tops, they pop on and off after you use a small flat blade driver to lossen the small band clamp thingy. (technical term)
Old Jun 17, 2010 | 11:02 AM
Wicked 996's Avatar
Wicked 996 is infamous around these partsWicked 996 is infamous around these parts
cheap part - pelican parts!
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
qbanchin
Aug 24, 2015 10:31 AM
JMon
Aug 21, 2015 08:20 AM
