Help With Engine Plate Install
Old Jun 20, 2010 | 12:26 PM
rennwerkes's Avatar
rennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to beholdrennwerkes is a splendid one to behold
Seems as though all the searches I do on this subject has comments that it was a five minute job.
Hmmm...
I guess I'm not that mechanically inclined!
On my 02 I pulled the three bolts out per instructions.
However, my question is do you install the tray tabs OVER the hose clamps or UNDER them? Also, if you install under the clamps do you need to shave the tray tabs so that they'll fit better?
On the front installation point, there's a hose that runs across the front of the engine. Do you just "make" it fit? In this situation I'm assuming you mount the tray over (on top) the hose clamp?
Any advice/comments are appreciated!
Old Jun 20, 2010 | 12:53 PM
my996's Avatar
1999 C4 Cab 6 Speed
my996 is infamous around these parts
I remember having to tap into the engine cover so the cover would not rattle.
Old Jun 20, 2010 | 05:41 PM
gixxer638's Avatar
gixxer638 is infamous around these partsgixxer638 is infamous around these partsgixxer638 is infamous around these partsgixxer638 is infamous around these partsgixxer638 is infamous around these parts
is the porsche part you are talking about mine is in the mail now
Old Jun 20, 2010 | 06:05 PM
gixxer638's Avatar
post some pic please
Old Jun 20, 2010 | 09:12 PM
rennwerkes's Avatar
Yes, it's the factory part.
Old Jun 22, 2010 | 01:02 AM
rennwerkes's Avatar
Anyone?
Old Jun 23, 2010 | 05:46 PM
gixxer638's Avatar
i got mine today from suncoast porsche i put it over the top of all the pipe clamps. i had to grind the two side tabs just a small amount above the hole. the back hole i installed a rubber gromit where it rests on the block. i gave it a little bow from front to back so it will not hit the oil pan at all
Old Jun 23, 2010 | 07:38 PM
rennwerkes's Avatar
Thanks for the feedback.
I'll give it another shot.
ECS Tuning - VW
Aug 20, 2015 03:07 PM
TrackOne
Aug 20, 2015 12:56 PM
Aug 20, 2015 12:17 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
