Where Is My OIL COOLER ???
Old Aug 6, 2010 | 08:44 AM
BiteEmNBeatEm's Avatar
BiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud of
Okay i just want to be able to pull off my oil cooler ( oil/water heat exchanger ) on my '00 996 and pressure test it just to eliminate it as the cause of my intermix issure. does any body hear have any pictures of where it is located? Of maybe have a DIY on how to remove it?
Old Aug 6, 2010 | 10:42 AM
GREERJ1's Avatar
GREERJ1 is infamous around these parts
It is on the right side, top at tranny, block connection. To get at it, you will have to remove all the plastic manifolds on the top right side of the engine, or, remove the tranny and get at it from behind. PITA for sure. Here is a link http://dcauto.gotdns.com/illustration/index/454857735
Good luck
Old Aug 8, 2010 | 05:47 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
You can get the oil cooler off without removing the manifold. Yes it is a PITA but it can be done.
Fadi
Aug 17, 2018 05:16 PM
JQGS
Oct 18, 2015 06:19 PM
ECS Tuning - BMW
Sep 22, 2015 07:31 AM
m_motorsport
Sep 2, 2015 12:53 PM
