Cleaning the MAF Sensor
Old Mar 1, 2005 | 06:09 PM
lceniza's Avatar
lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !lceniza Is a GOD !
Has anyone done this recently? Anyone know where I can find DIY instructions on cleaning the MAF? I got the electronic cleaner but I don't know how to take the MAF out...
I'm paranoid of damaging the MAF sensor...since I've been told that the reading is somewhat connected to the ECU and relates to how much fuel is injected into the engine. (I thought the MAF was just a smog check device but it turns out to be critical to the engine functioning properly).
Any advice would help.
Thanks.
Old Mar 1, 2005 | 09:22 PM
evo_333's Avatar
evo_333 is infamous around these partsevo_333 is infamous around these parts
you might want to check rennlist and search that... I remember someone doing that awhile back...
Old Mar 2, 2005 | 01:41 PM
wyo996's Avatar
wyo996 is infamous around these parts
I just cleaned mine and it worked. Remove with torx tool (2 screws) and disconnect wiring. Spray with quick dry electrical cleaner several times, I did it 3, until it looks clean. The wire electrode with the resistor in it is all you need to spray. Let air dry and replace. I also have a new one ready from Brandywine for 381$. Will
Old Mar 2, 2005 | 02:59 PM
lceniza's Avatar
Wil,
Is it the one connected to the air filter box with two very small torx screws? I will try it tonight.
Thanks so much.
Old Mar 2, 2005 | 11:55 PM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Why are you cleaning it? That's something I would try to avoid if possible. The only reason why it would need cleaning is because you are using an after market cold induction kit that has a K&N filter that uses oil. If you are using that type of filter, cut back on the oiling because it will work better with out too much oil applied to the filter plus it won't coat your MAF with oil. Just my $.05.
Old Mar 3, 2005 | 11:39 AM
lceniza's Avatar
Yeah, I do have a K&N Filter on. The CEL came on about a month ago and has not gone off. Before, it usually comes on and goes off after a day or two of driving.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
jaehoppa
Oct 22, 2015 09:17 PM
B8_RDC
Sep 3, 2015 07:13 PM
WheelB
991 Turbo Vendor Classifieds
Sep 3, 2015 10:26 AM
