cd player won't turn on (do i need code?)
Old Nov 27, 2010 | 10:33 PM
turbo_secret's Avatar
turbo_secret is infamous around these partsturbo_secret is infamous around these parts
after replacing the battery, the cd player will not turn on now. I heard that i need a code for the cd player if so where could i get the code?
Old Nov 27, 2010 | 10:45 PM
rrrruben's Avatar
rrrruben is infamous around these parts
The code card is attached within the original owner's manual. I have a feeling you do not own it. If so, for a nominal fee, a trip to the dealer should remedy your issue.
Old Nov 28, 2010 | 05:07 AM
02TX996Cab's Avatar
02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold
Renntech's admin/P-car guru has a program that reportedly can retrieve unlock codes for many Becker audio units. Consider joining and following his "lost radio code" thread: http://www.renntech.org/forums/index...howtopic=18982
Otherwise, off to your local *stealer* for their help to unlock the radio. Make sure you get the code, write it down and store it in a secure place (along with your car's key codes...).
Good luck
BLKMGK
Sep 19, 2015 03:51 PM
Korntera
Sep 15, 2015 08:20 PM
katyrow
Sep 7, 2015 10:17 AM
DLF
Cayenne Turbo
Sep 3, 2015 01:36 PM
AuZZie
Sep 2, 2015 04:26 PM
