Help with putting the (third brake led) back to the top not wing.
Old Jan 27, 2011 | 06:33 PM
Nine_Eleven's Avatar
Nine_Eleven is infamous around these parts
I just sold my wing and now I have to put the led brake back to the top (green arrow). I see the wire but when I plug it in led wouldn't work but when I plug it in the bottom harness it would light up (red arrow).
How do I access the top harness plug (green plug)?
Old Jan 27, 2011 | 06:53 PM
juanchi300's Avatar
juanchi300 is infamous around these parts
check with a tester if a 12v signal is in one of the wires when you put the brake pedal, if you see a 12v signal , just put the other wire to ground.
i did it inside the car (take out the rear carpet cover and you are going to see the wires of the 3rd brake light.
hope this help you.
Old Jan 27, 2011 | 08:17 PM
Thanks but which rear carpet cover? Back panel? Picture please.
Old Jan 27, 2011 | 11:30 PM
Dennis C's Avatar
LED lights are sensitive to polarity, unlike incandescent bulbs.
Did this LED light work before?
Old Jan 28, 2011 | 01:32 AM
FLY996's Avatar
FLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud of
[quote=Dennis C;3107065]LED lights are sensitive to polarity, unlike incandescent bulbs.
Right. I had to reverse the plug wires to get my LED 3rd brake light to work.
Old Jan 28, 2011 | 04:59 AM
juanchi300's Avatar
behind the rear seats under the rear glass.
Old Jan 28, 2011 | 09:36 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Doesn't the rear spoiler have to be in the down position for that 3rd brake light to work? Maybe the car thinks the rear spoiler is in the up position.
Old Jan 28, 2011 | 11:15 AM
Thanks!
This makes sense. My OEM wing is disabled.
Old Feb 1, 2011 | 02:56 PM
If I plug it on the lower plug it works (green arrow) If I plug it to the upper plug (red arrow) doesn't work.
Anyone know why?
Old Feb 1, 2011 | 03:09 PM
function12's Avatar
Again the green arrow plug is the normal 3rd brake light. The red arrow is the 3rd brake light with the spoiler in the up position. The red arrow harness only functions with the spoiler in the up position.
Old Feb 1, 2011 | 03:29 PM
So which means my wing is in up position. How do I put it back to down position so the green plug can work.
Because I'm putting the GT3 MKII wing and the brake lights needs to be back on the top regular place. Had the break light on my RUF wing.
Old Feb 1, 2011 | 04:40 PM
HxCforlife's Avatar
Awaiting Email Confirmation
HxCforlife has a spectacular aura aboutHxCforlife has a spectacular aura about
There is a switch on the fuse panel that raises and lowers the wing. Just press the down button. But if i'm not mistaken if the wing is left up when you turn the car on and off it should go down on it's own.
Old Feb 2, 2011 | 08:36 PM
So the switch by the fuse below the steering wheel, if I press down it should work? Will I hear anything from the motor?
Old Feb 2, 2011 | 08:40 PM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
sad to see the kit broken up...
A
Old Feb 8, 2011 | 11:58 PM
So I did push the button down and I hear some clicking noise while holding the button. But still now lighting up. This led works when plug on the bottom harness (green arrow)...
What's going on here? I need this brake light to work since I change my wing to GT3 MK2 I need this light to work. I don't like not having the 3rd brake.
