Can a E GAS engine be installed to a NON E Gas car?
Old Feb 2, 2011 | 12:18 AM
rrdralli's Avatar
rrdralli is infamous around these parts
Does anyone know if a E-Gas throttle body engine can be used in a NON E-Gas car? If it can be done, is it hard? thanks
Old Feb 2, 2011 | 07:59 AM
rb101's Avatar
rb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to behold
I think it can be done. You would have to replace the DME, throttle body, petal, and get it all wired. Is there a reason you want to?
Old Feb 2, 2011 | 01:00 PM
Byprodriver's Avatar
Byprodriver is infamous around these parts
If you have a 1999 996 & want to install a 2000-2001 3.4 simply install your intake & throttlebody on the new engine everything below interchanges.
Old Feb 5, 2011 | 02:31 AM
rrdralli's Avatar
Thanks guys...
Old Feb 5, 2011 | 10:14 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Way too much work to try to install the electronic throttle in a cable throttle car. Just swap the cable throttle body and a couple of supports/brackets onto the E-gas engine and you are good to go.
Old Feb 8, 2011 | 02:11 AM
rrdralli's Avatar
thanks, the main reason i ask the question is my current engine is having oil leaks from many areas and also having a few probs so I got a hold of another engine but its an E gas motor so I just wanted to make sure it will work before I take things apart.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
Aug 20, 2015 12:17 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
