PIC REQUEST 18x12 on Narrow body
Old Feb 28, 2011 | 05:40 PM
Nine_Eleven's Avatar
Nine_Eleven is infamous around these parts
I would like to see some 18x12 on the narrow body 996 with info (width, offset, tires)
Old Mar 2, 2011 | 07:13 PM
balefire's Avatar
balefire is just really nicebalefire is just really nicebalefire is just really nicebalefire is just really nice
18x12 is impossible on an NB.
18x11.5 et 65 might be possible on a mk2 NB.
18x11 et 60 fits easily.
Old Mar 2, 2011 | 07:20 PM
It is possible. 18x12 +63mm 8.98" Back spacing. I talk to CCW in Florida. They say GT3's run them. I just want to see some pictures...
Old Mar 2, 2011 | 09:17 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
I don't think you will have the same fender liners and suspension geometry of a gt3, but I'm not sure.
I had 11s on my lowered NB and it rubbed the inside liner in two places and I had to roll the outer fender.
Old Mar 2, 2011 | 09:18 PM
It all depends on the offset. CCW says they run 12's on 911 and 911 GT3.
Old Mar 3, 2011 | 04:41 AM
balefire's Avatar
You are right. 18x12 is possible on a NB GT3 but not a non-GT3 NB unless you do this:
http://forums.rennlist.com/rennforum...on-996-c2.html
I'm running 18x11 et 51, 295 tire on my mk2 NB 996, US M030, camber -1, non rolled lip and it is at the absolute limit laterally in terms of clearing the fender under compression. So I estimate that 18x12 et 63 would not clear the fender under compression (i.e. stick out too far) by 13 mm.
You will have an ever more difficult time since mk1 rear suspension is less accomodating than a mk2 rear suspension in terms of wide wheels.
Old Jul 2, 2012 | 03:42 PM
matthewbounds's Avatar
matthewbounds is a jewel in the roughmatthewbounds is a jewel in the roughmatthewbounds is a jewel in the rough
So a 55 offset would rub.
Old Jul 2, 2012 | 04:04 PM
Steve's 996's Avatar
Steve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud ofSteve's 996 has much to be proud of
I use 11 wide, 65 offset with a 295 tire. No rubbing issues, but i'm not sure there is room enough for another 1". Mine is lowered on Pss9's.
L.A.P.
Oct 26, 2015 11:49 AM
gulf gt
Aug 27, 2015 10:27 AM
Zero911
Aug 24, 2015 06:51 PM
Mar48
Aug 24, 2015 01:13 PM
Aug 21, 2015 06:34 AM
