For those that have had engine rebuilds...
Old Mar 23, 2011 | 03:03 PM
scantu's Avatar
scantu is infamous around these parts
How long did the job take to do from start to finish? Im at 5 months with an independent Porsche Guru and still waiting. Stripped all the way down, had the heads worked, the block examined and the crank polished. Everything went together with new bearings and ARP bolts.
Thanks guys,
Sergio
Old Mar 23, 2011 | 08:47 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Thanks guys,
Sergio
5 months? Did you request a hand built engine and they took you literally? Seriously, what do they say is the holdup? Way too long imo. Most opt for a remanufactured engine from the factory but I guess you knew that. Personally I think something is amiss here. You see this kind of stuff when the shop is insolvent ie can't afford parts, etc. There is a point where patience is not the answer. I think you need to be reconsidering your options. You may be able to have your property removed to a local dealer and take them to small claims court. Before they declare bankruptcy.
Old Mar 23, 2011 | 09:17 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Moderate custom Turbo engine rebuilds even take less than 5 months. Yes, a ground breaking Turbo engine rebuild takes 1-2 years. (see the turbo section). A NA carrera engine rebuild? 4-6 weeks at the most. They must be doing your engine at their spare time.
Old Mar 24, 2011 | 11:17 AM
tarzancoe's Avatar
tarzancoe is infamous around these parts
My engine rebuild, which included new cylinder sleeves, head gaskets, and a few updates, took around 40 hour labor. If that.
Old Mar 24, 2011 | 05:00 PM
uberpoop's Avatar
uberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond repute
tarzan, what was your cost? where'd you get it done? thanks.
scantu- like others... way too long of time for a rebuild. i'd imagine you could get a 3.8L and the brains installed quicker.
Old Mar 24, 2011 | 06:28 PM
Mother's Avatar
Mother is infamous around these parts
Try Strasse auto in Newport, CA engines are already rebuilt and usually in stock just turn in core and pick up rebuilt one949-645-1928.
Old Mar 25, 2011 | 12:46 PM
tarzancoe's Avatar
PM Sent
Jul 29, 2019 11:13 AM
saline
Oct 7, 2015 07:29 AM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
