Lubrication of power seat rails
Old Apr 6, 2011 | 11:21 AM
CoolHand's Avatar
CoolHand is infamous around these parts
When I move my seat all the way back I get a clunking grinding sound.... my guess is that it needs some lube or grease on the assembly?
Anybody that has done this before please let me know your best bets...
Thanks in advance..
Old Apr 6, 2011 | 11:25 AM
Zookie's Avatar
i would like to know as wel, i know there is a TSB on Renntech, but there has to be simpler solution
Old Apr 7, 2011 | 10:23 PM
pterfloth's Avatar
pterfloth is infamous around these parts
I had a clicking sound from my power, heated driver's seat around corners that was driving me batty. I was convinced something was loose.
I used the seat removal procedure in the service manuals to remove the seat and found the clicking was just the result of loose change that had fallen into the seat rails, etc. Fixed the problem and made $1.62!
Removing the seat is really simple, only 4 torx screws need to be removed and the electrical connections unhooked and voila. I found hair and grime caught up in the gears and rails and cleaned them out and added some fresh grease.
I'd encourage you to give that a try. Your issue might be very simple too.
Old Apr 8, 2011 | 10:26 AM
CoolHand's Avatar
Thanks for your response,
I was looking at it yesterday and it looks pretty straight forward, what grease did you use? I was thinking of a marine bearing grease just for longevity purposes.
I also have and need to swap out the seatbelt buckles and the center console, window switches and it looks like I need to take out the seats for that work anyways. Maybe this weekend...
Old Apr 8, 2011 | 11:36 AM
pterfloth's Avatar
I used marine grease because I had some around for my boat and its high quality stuff.
The seat belt buckles are attached to the seats, so you'll need to remove them to replace. The console is quite easy. Use the B&M short shift kit installation instructions as a guide.
http://www.bmracing.com/bmracing/ins...ruction/67.pdf · PDF file
Good luck. Its easier than you expect.
Old Apr 8, 2011 | 12:40 PM
CoolHand's Avatar
Thumbs up
www.bmracing.com/bmracing/installation_instruction/67.pdf · PDF file
Thanks so much for the tip and the short shifter manual..... makes a world of difference then just blindly removing things.
Old Apr 8, 2011 | 03:23 PM
pterfloth's Avatar
My pleasure. If you need instructions for removing the seats send me an email to terfloth@telus.net and I will be happy to send you a copy.
SharkyShark20
Sep 19, 2015 09:54 PM
Konea420
Aug 25, 2015 09:44 AM
pwdrhound
Aug 23, 2015 07:36 PM
pwdrhound
Aug 20, 2015 05:54 AM
