Who has the Highest Miles on the odo and what oil are you using?
Rating: Thread Rating: 2 votes, 3.00 average.
Old Jan 16, 2012 | 07:15 PM
luanta's Avatar
luanta is infamous around these parts
Originally Posted by Parkcity911
Yes, LN does like the 5W-40. Plus, they specifically mention to use the oils with higher concentrations of Zinc and Phos. Sounds like a few have had exceptional luck with the Mobil too / the proof is there. I'm curious if the high mileage porsche had a new IMS bearing too. If not, wow...good job.
I am wondering why only LN Engineering has pursued this research. Does Porsche R&D not agree with this issue?
Old Jan 16, 2012 | 09:56 PM
sctx's Avatar
sctx is infamous around these parts
2000 C2 Carrera - currently at 123K miles. From day 1, Mobil1 0W-40 is the only oil ever used along with consistent regular maintenance. Performance is amazing and is driven almost every day. Love this car!!!.
Old Jan 16, 2012 | 10:21 PM
afletche's Avatar
afletche has a spectacular aura aboutafletche has a spectacular aura about
Did you do your IMS on your car? That is great...keep up the good work. At those miles I'd 1/2 th miles between your changes at least. Just my .02 as you're doing great on the miles.
haven't done the IMS, will do it when/if I need to do the clutch. i know i should probably do the oil more often, but it just never seems to happen. i tend to forget until it's time to get the next 15k service. usually i don't even have to top it up between services. it seems pretty much bullet proof! although this last service was the first signs of things crumbling - needed coils, spark plugs and a battery (they were all originals)
Old Jan 18, 2012 | 08:35 AM
WDC 911's Avatar
WDC 911 is infamous around these parts
+1 but with 113k
Originally Posted by 996tofast4911
117k Mobil 1 0w-40..... No issues
Old Jan 25, 2012 | 03:11 PM
slowlude22's Avatar
slowlude22 is infamous around these parts
145K on a 99 C4 with Mobil 0-40
Old Jan 25, 2012 | 05:39 PM
luanta's Avatar
I'm lovin the results of 0w-40!!!!!
Old Jan 26, 2012 | 07:08 PM
GREERJ1's Avatar
GREERJ1 is infamous around these parts
01 C2 with 99,680. used M1 0-W40 for the first 90,000 Now with the L&N upgrade I use 5 qts of M1, 0-w40 and 4.5 qts of 5w50
Old Jan 26, 2012 | 08:33 PM
JB Lifeguard's Avatar
JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !
5-40 Mobil 1 at 95752 ( this afternoon). Replaced clutch and put in ln bearing at 89700 mi. This was the second clutch replacement in this car ; first done by previous owner at 45000 mi. I drive it 6 days a week, and drive it hard every day ( one it gets to 180). I put about 10 k mi a year, including 1000 miles at driving events.
If you goes think this car is "unreliable" my initial 911's from the '70s would be ready for new valves and guides at 75k mi.
Job
Old Feb 28, 2012 | 09:29 PM
b-man's Avatar
b-man is infamous around these parts
200,000 miles on a 2002 996. I've had it since new and have only used Mobil 1 0W-40. But I'm on my second engine (replaced at about 142,000 miles).
b-man
Old Feb 28, 2012 | 09:57 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
b-man
What failed?
Old Feb 29, 2012 | 08:19 AM
b-man's Avatar
Originally Posted by geetee
What failed?
Here are some older messages I had previously posted:
"If I remember correctly, the variocam or variocam plus or whatever it's called wasn't working properly and would change the valve/cam timing incorrectly. Then the engine would run really badly, so badly that it would sometimes shut off ignition to a cylinder. That would be hard on the engine and I eventually blew a head gasket."
and
"There was a LOT of smoke, and there was coolant coming out of both exhaust pipes. I know, I must have imagined that because these cars rarely have head gasket problems and rarely have engine replacement problems too (sorry, I can't help being a little bitter and sarcastic about this).
My mechanic is very good, very experienced, and very honest.
I can't remember the details about the engine problem(s). But, I think there were several related issues that triggered check engine light (constant on and flashing light) for a while. Sometimes it would kill ignition (or maybe fuel?) to the affected cylinder, which I understand to be the limp home mode. Then the resulting uneven pressures would be the biggest contributor to the blown head gasket (if I remember this correctly).
When the one cylinder would shut down, I would usually kill the ignition completely with my key, then start the car again, usually while the car was still moving at speed! That would always (if I remember correctly) fix it temporarily.
When I looked into this very closely (with my mechanic) and thought this through very carefully, the cost of fixing the problem(s) didn't make finanical sense to me. It may have had something to do with not being completely sure the engine would be fixed, all of the labor/time involved, etc.
It made more sense to me to get a replacement engine when the first one let go. So I kept driving it until it did."
b-man
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
alevine
Nov 4, 2015 10:05 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
