Who has the Highest Miles on the odo and what oil are you using?
Rating: Thread Rating: 2 votes, 3.00 average.
Old Jan 15, 2012 | 09:19 PM
luanta's Avatar
luanta is infamous around these parts
Hello Everyone, I am a newbie with an 2004 C4S. I've been trying to read up on the different types of oils used in 996's. I've read so many different views on what to use ( M1 0w-40, Castrol 5w-40, Motul 5w-40, M1 15w-50, M1 Delvac 5w-40 etc.) I have always said that the "Proof is in the Pudding". Who has the highest milage 996 with original engine and what kind of oil are you using?
Old Jan 16, 2012 | 02:41 AM
bukers80's Avatar
bukers80 is infamous around these parts
porsche 996 3,4 1999 96000miles,Elf 5W40 is super.
I used castrol and damaged the engine
Old Jan 16, 2012 | 05:52 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
Sold my car with 157,000 miles. Only used Mobil1 0-40
Old Jan 16, 2012 | 08:43 AM
luanta's Avatar
Interesting about castrol. There are some on the web that said castrol witj the higher zinc content would actually be better. Thank you for sharing sir.
Old Jan 16, 2012 | 08:46 AM
luanta's Avatar
157k? Did you do the ims upgrade or was it the original? Im impressed. Thank you.
Old Jan 16, 2012 | 08:51 AM
luanta's Avatar
Some people have said that using a thicker viscosity oil is better for the ims. I believe that even LN Engineering was referring to 5w-40.
Old Jan 16, 2012 | 09:57 AM
Parkcity911's Avatar
Parkcity911 is infamous around these parts
Yes, LN does like the 5W-40. Plus, they specifically mention to use the oils with higher concentrations of Zinc and Phos. Sounds like a few have had exceptional luck with the Mobil too / the proof is there. I'm curious if the high mileage porsche had a new IMS bearing too. If not, wow...good job.
Old Jan 16, 2012 | 10:23 AM
afletche's Avatar
afletche has a spectacular aura aboutafletche has a spectacular aura about
97,000 on a 2000 cab. mobil 1, not sure on viscosity as it only gets changed every 15,000 when i get it serviced at the local indy.
Old Jan 16, 2012 | 10:48 AM
Did you do your IMS on your car? That is great...keep up the good work. At those miles I'd 1/2 th miles between your changes at least. Just my .02 as you're doing great on the miles.
Old Jan 16, 2012 | 11:25 AM
logray's Avatar
logray is infamous around these partslogray is infamous around these parts
Where's the popcorn icon when you need it.
Old Jan 16, 2012 | 11:55 AM
996tofast4911's Avatar
996tofast4911 is infamous around these parts
117k Mobil 1 0w-40..... No issues
Old Jan 16, 2012 | 12:40 PM
dennish's Avatar
dennish is infamous around these parts
My perception from all my reading is that Mobil 1 0-40 is FAR FROM IDEAL for our cars. Seems like the opposite. It has some good and actual results. Anecdotal?? I was actually a little worried because I used Mobil 1 when I did my IMS Guardian because I had 10 qts in my shop. Now, I won't worry (as much). Ha
Old Jan 16, 2012 | 01:59 PM
JoelPirela's Avatar
Original engine with no IMS upgrade. No problems using Mobil1 0-40. at least for me.
Old Jan 16, 2012 | 07:09 PM
luanta's Avatar
I'm very impressed with Mr. Joel Pirela's results with M1 0w-40!!!! Keep it coming folks.
Old Jan 16, 2012 | 07:11 PM
luanta's Avatar
I am impressed. Thank u sir.
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
