996 engine code po495 and po430
Old Feb 27, 2012 | 07:55 AM
The MSTRISS's Avatar
The MSTRISS is infamous around these parts
Just had my c4 cab in for check engine, Pulled code myself and had po495 and po430. Took it in they smoke tested for leaks found none so only thing they thought it could be is mass air, replaced it light went off for about 150 miles back on again!! Help please....
Old Feb 27, 2012 | 08:54 PM
bensonJ's Avatar
bensonJ is infamous around these parts
P0430 is for catalytic converter efficiency and has almost nothing to do with the mass airflow sensor or smoke tests. Find a competent shop to actually diag. these codes. The cat. efficiency can be checked by comparing oxygen sensor activity before and after the cat. I've never heard of a P0495 on a Porsche before. Good luck and let us know what happens.
Old Mar 5, 2012 | 07:01 AM
Not sure if I have the right code number but it is for the sencondary air pump bank two. smoke tested no leaks only other thing I can think of is the port has some blockage. Is this a common issue?
Old Mar 5, 2012 | 10:15 PM
Sharp's Avatar
Sharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud of
P0430: Three Way Catalyst Conversion, Bank 1 - Above Limit
P0495: Fan Speed High
hope this helps!!
useful site: http://www.innova.com/
tropicatango
Jun 8, 2025 01:00 PM
Jul 29, 2019 11:13 AM
carwash
Sep 29, 2015 10:43 PM
oddjob142
Aug 24, 2015 05:49 PM
Aug 19, 2015 06:55 PM
