Oh No over rev!!! Help
Old Jul 14, 2012 | 03:21 PM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Ok,
Me and the "car" were out playing around on the twisty turnies here in Brandon and I accidently took her to 7100 -7200 rpm's in second It was a total accident, but when she got there she skipped like the clutch was slipping, and I immeadily up shifted. So, I drove her home still pushing rpm's to 6k and she was perfect! Question, did I hert her? She has brand new oil and all fluids. Driving home she didn't miss a beat.
Is she ok?
Old Jul 14, 2012 | 04:21 PM
jhthornley's Avatar
jhthornley is a glorious beacon of lightjhthornley is a glorious beacon of lightjhthornley is a glorious beacon of lightjhthornley is a glorious beacon of lightjhthornley is a glorious beacon of lightjhthornley is a glorious beacon of light
She is toast. Drive her up here to NC, and i will take her off your hands AND buy you a return flight.
Old Jul 14, 2012 | 05:07 PM
FLA996TT's Avatar
Ok, Ok, would that be "Melba Toast" or "Burnt Toast?" Thanks
Old Jul 14, 2012 | 05:36 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
sounds like rev limiter got activated giving that funny feeling like the clutch is slipping.. as it should. Do not see an issue.
Old Jul 14, 2012 | 06:10 PM
jhthornley's Avatar
I think its ok...as demonstrated by your journey home w runs up to 6k rpm...
Doesnt feel good when u mess up... i touched gears once when having a brain fart...
Old Jul 14, 2012 | 09:56 PM
dotframe's Avatar
dotframe is infamous around these parts
Doesn't sound like you over-revved it if you just ran the RPMs up while in gear. You over-rev by downshifting to too low of a gear and the engine is forced to rev higher than the limiter.
Old Jul 15, 2012 | 04:00 AM
stephan_porsche's Avatar
stephan_porsche is infamous around these parts
Your fine. Don't do it again! But you will know if you damaged her, the transmission would have exploded or you would have Oil/Coolant pouring out your exhaust.
Old Jul 15, 2012 | 05:10 AM
FLA996TT's Avatar
I will not! It really scared me, the 928 I had years ago had little warning lights when you got close to the redline.
Old Jul 15, 2012 | 05:23 AM
02TX996Cab's Avatar
02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold
No problem whatsoever. You hit red line and the electronic rev limited kicked in, which is exactly what should happen. There is very little risk of damage doing this, since Porsche designed the engine to rev and set the limit at a safe level.
The overrevs that hurt are when you mis-shift--like going from 5th to 2nd instead of to 4th. The electronic rev limiter can't help you there. These "money shifts" are what you absolutely must avoid.
Old Jul 15, 2012 | 10:22 AM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
Yup -- sounds like you hit the rev limiter. Shouldn't be a problem. The "sputtering" feeling is how the car keeps you from going over the limit -- perfectly normal. In fact, I would say it's really no problem if you do it again -- happens pretty often to people at the track. The only thing you want to really avoid is shifting too far down into the wrong gear by accident and forcing the engine to go past the rev limiter (that's bad news -- hence the term "money shift").
Old Jul 15, 2012 | 04:05 PM
FLA996TT's Avatar
Thanks Guy's
Hey,
I made it up to her today, a nice warm bath with Zymol clear, then a second bath with Zymol wash, and then 3 nice masages with Zymol cream. And then a nice rub down inside with Zymol leather conditioner.
Thanks again, we were sad at the time, I don't want to do anything to hurt my baby, I love her.
Old Jul 15, 2012 | 05:36 PM
lowpue's Avatar
lowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud of
When I took my 996 out to the track last weekend I kept hitting the limiter coming around the bend in second into the straightaway, shifting to third it just all seemd to work....I just didn't worriy about it. I love the limiter since this way I know I am getting the Revs. Gaol of course is to shift just before.
Old Jul 15, 2012 | 09:52 PM
Aerodude's Avatar
Don't baby your car. Porsche's like to be driven. If you baby your car, it will act (drive) like a baby....
Old Jul 16, 2012 | 06:15 AM
FLA996TT's Avatar
Oh I don't when I drive her, we were having a great time and I was pulling her right to 7k and shifting up, I hit it in second because I took my eye off the tac. We actually hit some nice speeds and the Fisters exhaust was sounding so nice.
I only baby here keeping her clean, and ready to go!
Old Jul 16, 2012 | 06:17 AM
FLA996TT's Avatar
That's what happened to me, someone in a minivan pulled in front of me while just upshifting to second and that's when it hit but I clutched and hit third in a nano second.
