996 Front turn signal replacement
Old Jul 14, 2012 | 07:56 PM
jseese's Avatar
jseese is infamous around these parts
Any help in how to replace front turn signal bulb would be greatly appreciated.
thanks
Old Jul 14, 2012 | 08:18 PM
wyovino's Avatar
wyovino is a jewel in the roughwyovino is a jewel in the roughwyovino is a jewel in the rough
Look in your owner's manual. The whole headlight assembly slides out for easy replacement of all of the bulbs.
There is a special tool in your toolkit. Pull the carpet down in the frunk. There is a big, black, round rubber plug that you just pull out. Insert the tool and turn it ( I forget which direction, forward or back) and it will click and the whole light will just pull out. There are no wires to worry about.
It's far easier to change bulbs on your 996 than it is on most cars. After you do it the first time, you'll be able to change any bulbs in under 5 minutes.
Old Jul 15, 2012 | 07:10 AM
invius's Avatar
invius is infamous around these parts
Also, when you put it back in and turn the tool the other way to lock the headlight assembly back in, it will click again. The first time that happened, it scared the **** out of me, because I was thinking I broke the assembly, but the click (which is VERY loud, at least on mine) just lets you know that it has seeded in it's housing properly.
Old Jul 16, 2012 | 07:48 AM
jseese's Avatar
Front Light Assembly
Thanks so much for your help.
Old Jul 19, 2012 | 11:39 AM
996_911C2_Dhru's Avatar
996_911C2_Dhru is infamous around these parts
What they said ^--
By far the easiest front light replacement of any car I've owned. The HID conversion is easy too. Here is a video that might be helpful.
Old Jul 19, 2012 | 11:49 AM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
Just a reminder to make sure the headlamp assembly is properly in the slots or you may break the stationary connector if you force it to lock. How do I know you ask? LOL
Old Jul 22, 2012 | 11:02 AM
SoCal_02_911Cab's Avatar
SoCal_02_911Cab is infamous around these parts
Hi,
I just recently did this and used the exact same video...very helpful and easy as everyone has suggested.
However.....my left turn signal still does not work. I replaced the bulb but it's still not blinking. I also noticed that the bulb I took out did not have a broken filament, so my conculsion is that it's not the bulb at all. After I replaced the headlight assembly (I did it twice, using two new bulbs) all of the other lights (i.e. the actual headlight) still work, so it's not a case of the assembly not fitting tight when I put it back in.
So....does anyone have any other suggestions? Is there a fuse for the left(steering wheel side of the car) blinker that I should check, and if so, any suggestions (and/or pictures) on where that would be?
Thank you.
Old Jun 20, 2015 | 02:24 PM
troti's Avatar
troti is infamous around these parts
Hey SoCal_02_911Cab...I have the exact same problem as you now with my left front turn signal. Did you ever figure out the problem??
cadman
Nov 13, 2025 08:57 AM
Enemy
Nov 10, 2015 08:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
