Convertible top control
Old Aug 27, 2012 | 06:34 AM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
Originally Posted by harvs
i did this to my car last week.. LOVE IT... especially in traffic. All you do is cut one of the wires that checks speed. Since you're asking.. i'm assuming you have a pre '02 model... mine is a '99 and i cut the pink/grey wire going to the control unit (behind the driver's side roll bar, under the all the covering)
I believe that the control unit for the convertible top of a 1999 C2 Cab is located behind the rear seats. I am able to remove 2 Philips screws and then remove the panel from behind the back seats but I dont seem to be able to get much further. At this point I can see the 2 airbag type metal holders which would release the roll bars behind the heads of the back seat in the case of a car roll over. I need to remove the top part which has the 2 roll over insets in it so I can see the other side of the roll over cannisters. I have removed a further 2 philips screws which attach this top to the cannisters but can get no futher as the top will still not come off. Has anyone any ideas. Thanks.
Sorry I just discovered my 996 essential companion Book explains how to access this compartment..
Last edited by Hurdigurdiman; Aug 27, 2012 at 07:55 AM. Reason: essential companion 996 book explains all.
COBB Tuning
Mar 29, 2016 09:26 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
Walorus
Aug 18, 2015 01:39 PM
