18x9 front - is 255/35 okay?
C2 or a C4? You don't want to burn up the diff. if you're a C4.
255/35/18 is a perfect diameter match for 295/30/18. Both diameter's about 25 inches.
Im running 255/35/18 on the front on a 10 inch wide rim. It will be fine/fit on a 9 inch rim as well. Just make sure your wheel offset is good so that it won't rub on the strut or fender.
The ideal section width for a 9" rim is 255. However, 245/35/18 F + 285/30/18 R would be the best combo with a 10" rim at the rear. 255/35/18 F + 295/30/18 R would be the best combo with an 11" rim at the rear. Also, offset or ET is a factor. ~50ET for the former, and ~45ET for the latter. Good luck.
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
