My Tip_Tronic 996 4S Problems
Mother ffffffrrrrr.
My transmission shifted funny when the vehicle is cold first at start up as if it was slipping. When I would start it start driving it in auto or manual mode the rpms would jump up and downshift while driving. I got tired of it and decided to drop the pan drain fluid install a new filter and gasket flush it twice and then refill back up. Now the transmission operates even worse, when the car is warm it shifts up and down........... some one with the same issues? should I be looking at different transmission? 90K
Can I use friction additive oil? I think the previous owner already used it because the fluid was dark gray when I drained it.
Before the flush it would only do it when the car was cold the first 20 min of driving then it would shift somewhat normal now it shifts up down in 2-3.5K rpms as if the fuel pump was cutting out.
Get your radio code first though
tropicatango
Jun 8, 2025 01:00 PM
2lflat4
Nov 18, 2019 05:05 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
