Clear Third Brake Lights
Old Jul 22, 2005 | 08:42 PM
  #46
wross996TT's Avatar
I have to disagree!!! I tried installing in my TT and the seal (rubber gasket) is not as large as the stock version. The lense itself is the same dimensions, but the seal is different. It will fit in the slot, but will not seal properly. I was worried about water getting in there. I have included a bad picture comparing the two lights.
Old Jul 23, 2005 | 05:06 AM
  #47
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
Originally posted by Headdoc
Does this mean you have to take out the lights in the new harness and replace them with the existing lights? Is this hard to do?
No, you will need to swap the 2 pins in the harness connector
Old Jul 23, 2005 | 08:14 AM
  #48
drpaulmarsh's Avatar
San Diego Porschophile
drpaulmarsh is infamous around these parts
Have we decided a group buy price yet?
Paul
Old Jul 24, 2005 | 06:51 PM
  #49
Lizard1's Avatar
Lizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of lightLizard1 is a glorious beacon of light
gert - is there going to be a 6speed discount or group buy discount?
just let us know either way
thanks
Old Jul 24, 2005 | 06:52 PM
  #50
Lizard1's Avatar
for those of us that are mechanically/electronically inept - could you elaborate??
thanks!
Old Jul 24, 2005 | 07:48 PM
  #51
thanks!
Sure thing:
After the 3rd brake light is removed from the decklid (pop the cover on the right side of the lens, twist the securing pin slighty left and remove lens)
On the left side of the lens housing there will be a 2 wire harness connector, disconnect from the lens and swap the 2 wires by removing them from the connector, this can be done with a special tool or a very small thin blade screwdriver and re insert the connector into the lens
There is an alternate way to do this as well if you are not comfortable swapping the pins:
cut both wires and reconnect to the opposite one with the quick splice wire connectors that are supplied with the kit
Hope the helps you
Old Jul 24, 2005 | 08:03 PM
  #52
Lizard1's Avatar
thanks - i'll try it!
Old Jul 25, 2005 | 08:19 AM
  #53
Gert's Avatar
Gert is infamous around these parts
Not that I know of
Old Jul 25, 2005 | 05:05 PM
  #54
Holger B's Avatar
Holger B is infamous around these parts
Installed mine on Friday (sorry, no pics yet). I didn't have to swap the wires, plugged it in as is and it worked.
Thanks Gert!
Old Jul 26, 2005 | 09:30 AM
  #55
bavarian's Avatar
bavarian is infamous around these parts
I'm still on the fence. I am waiting to see a picture of a dark blue or black car--preferably a C4S, because the red reflector across the whole width of the car ties in well with the red third brake light IMO. (unless Gert comes up with a smoked version of that, too!!)
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Michael_s
Sep 11, 2015 08:03 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
Vrseis
Aug 20, 2015 07:41 AM
