If front hood left open, does the cargo light turn off? If so how long til'?
Old Dec 25, 2012 | 03:22 AM
Black_911's Avatar
Black_911 has a spectacular aura aboutBlack_911 has a spectacular aura aboutBlack_911 has a spectacular aura about
Reason I asked, it's because I charge my battery once a while with the trickle charger and charges it from the front (main battery connections) and I leave the front hood open while it's charging.
It gets annoying having to unplug the light from the harness every time.
Thanks!
Old Dec 25, 2012 | 08:04 AM
carsareart's Avatar
carsareart is infamous around these parts
I am not sure how long the light stays on. I normally unplug my light if the lid will be up long. I have wired a plug for my maintainer and I open my hood, feed the maintainer cord between the windshield and hood. I plug it in there and then close the hood. I use a Schumacher Maintainer. It has been great for years. My Sunday morning driving insurance
Old Dec 25, 2012 | 01:01 PM
Long Islander's Avatar
Long Islander has a spectacular aura aboutLong Islander has a spectacular aura about
I'm pretty sure the front trunk lamp turms off after a 1/2 hour and the rear engine lid lamp never turns off. To conserve battery power, I replaced my front trunk bulb and rear engine lid bulbs with 39 mm LED "festoon" bulbs from www.superlumination.com.
Another alternative is to install a rocker switch by cutting into the plastic trunk panel next to the trunk lamp so you can turn it off when you want. Radio Shack has some black ones that should be easy to install.
Old Dec 25, 2012 | 03:05 PM
zeeeeeee's Avatar
zeeeeeee is infamous around these parts
I use the CTEK 7002 smart charger with the cigarette lighter adapter. I just plug it in the cigarette lighter outlet and it works perfect.
MAcarbon
Mar 6, 2017 08:16 AM
MAcarbon
Aug 24, 2015 03:26 PM
MAcarbon
Aug 20, 2015 03:02 PM
MAcarbon
Aug 19, 2015 06:22 PM
MAcarbon
Aug 19, 2015 04:52 PM
