Has Anyone ever painted there brake hub?
With the large Techarts this part of the brake drum or hub (not sure) is ugly! Has anyone attempted to paint this? Also I would think that it would need some high temp paint because its probably gets pretty hot.. What do you guys think? I have to pull my rims off next week so I thought I'd would clean up around the wheel wells. Im going to paint it silver to match the rim.. Don I can't believe you haven't done this
kevin: here is how I do it. I paint the hub in place.
Take the wheel off (duhh)
Clean off the hub with carb cleaner, brake cleaner or what ever solvent you are fond of.
Mask off the caliper and pads
mask off the center spindle and nut
Use some good light grey engine primer
spray the hub. dont worry if you get any paint on the rotor surface. (but try not to get too much on there) The first time you brake, the paint will be worn off. That will also cut a nice line around the part you just painted.
Personally I would not care for silver, as they come from the factory in grey.
the last thing you might want to consider is to take some steel wool to the outside rim of the rotor to get rid of the rust and dirt that accumulates there. Be sure to blow out the steel wool particles real good so that they don't stick add add more rust. There are some that take engine paint that is dull gunmetal metallic grey and shoot the rotor cooling vanes as well.
Kevin & Orient,
I love the Techarts and the Carrera 5 spokes, they're soooo easy too clean. However, the new Cargraphics I put on my Cab are great. They hide everything. Rotor rust, hubs, etc. They're a little more work on the outside, but no more fuss on the inside!
Eric
Eric
Hi Kevin
Keep me posted on this one, I am interested in the results. Would Hammerite work ?? I did this to my MGB some years ago (brake capiliers) and a part from stone chips have very worked well.
Although with the proper product, the brake hats (bells) can be painted, eventually, generally sooner than later, they will get dirty. To increase both performance (as they will reduce very important unsprung and rotating weight) and looks you might consider a two piece disk and hat. Finally, if you do decide to paint the hats, take the disks off the car and carefully mask all other parts of the disk -- paint blocking either the holes or the vanes will have a negative effect upon performance -- but not nearly as bad and dangerous an effect as paint in the calipers or other parts of the vehicle that might result from painting on the car.
have to disagree with Robert
Painting the hat on the car is perfectly safe, A little overspray will be wiped clean by the pads. As far as blocking the vent holes, one has to aim at the hat, not the holes, and just spray on enough to do the job. There is more of an issue of buildup of pad dust blocking the holes in normal use than overspray from painting the hats.
I have been using this method for quite a while, and the car still stops just as good as ever.
overspray on the rotor being dangerous is in the same league as getting pregnant from toilet seats.
ECS Tuning - VW
Sep 2, 2015 09:03 AM
