Airbag Warning Light Problem??
Old Nov 6, 2003 | 08:25 PM
wino's Avatar
wino is infamous around these parts
I just noticed that when I start the car, all the warning lights come on, except the one for the airbag - is this supposed to happen?
Old Nov 7, 2003 | 03:37 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
Sounds like a question for your Dealer.
Old Nov 7, 2003 | 06:48 AM
ZX7R's Avatar
ZX7R is infamous around these parts
Page 45 in the '03 instruction manual spells it out fairly clearly....
Assume a fault if the following is ocurring
'Illumination of the airbag warning light during travel or repeated illumination longer than 5 seconds after the ignition circuit is switched on'
'Illumination fails to light up during ignition circuit activation'
Mind you - you could just have a dud globe in the cluster.
I'd get your dealer to check it out asap.
Costas
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
pwdrhound
Aug 23, 2015 07:36 PM
thegrillboy
Cayenne 958
Aug 22, 2015 09:24 AM
Walorus
Aug 18, 2015 01:39 PM
