Replacing Rear Shocks in Cab.
Old Mar 17, 2014 | 01:21 PM
lgl314's Avatar
lgl314 is infamous around these parts
More ? . . . 1999, 911, C2, Cab Needs new rear shocks. I've found good info in Rentech and the Bentley manual on coupes but absolutely no info on how best to change the rear shocks in a Cabriolet. Mostly need info on how to get at the top mounting bolts. Can they be gotten to with the top down (open)? I'm going out now and see what I can discover . . . and hopefully not break anything. Thanks in advance for the help. Larry
Old Mar 17, 2014 | 07:32 PM
RDykmans's Avatar
RDykmans is infamous around these parts
You have to partially open it, disconnect the cables and pull some covering out of the way.
Old Mar 18, 2014 | 05:58 AM
02TX996Cab's Avatar
02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold
If you read the full renntech.org thread (not the procedure itself, but the member posts) about installing the M030 RoW suspension kit, you'll find post #50. That post shares my experience installing that kit on my 2002 996 Cab and includes a link to another renntech article which explains in detail how you access the mechanical bits behind the rear seats.
The basic procedure for accessing the top rear strut mounts is as the previous poster outlined, but the renntech articles provide a lot more detail. I found the whole procedure to be quite simple after reading them.
Good luck!
Old Mar 18, 2014 | 08:12 AM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Larry,
I went through a different issue with the top getting stuck open,take a look at the instructions in the link for DIY Porsche 996 and 997 Carrera Hydraulic Ram Inspection and Removal Instructions
http://www.cabriolethydraulics.com/articles.php
r_matt_6
Oct 8, 2015 06:07 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
TrackOne
Aug 20, 2015 12:56 PM
