Help Please, P-Car Won't Start
Old Mar 24, 2014 | 06:17 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
I saw those after I wrote the post, the Bosch has more CCA's one is 850 and the other 900, which one did you use?
Originally Posted by Hurdigurdiman
You will get a cheaper Bosch Battery from Pep Boys. Just over a hundred Dollars. Thats what I use. The same make as was on the car when I bought it. You have to know the four number radio code to bring the radio back to working, if the battery was ever disconnected for any reason and obviously yours was for charging. Good luck.
Old Mar 24, 2014 | 07:34 AM
alpine003's Avatar
If you don't have radio code, just buy one of those $5 9volt plug in adapters to keep your radio juiced while swapping out the battery.
Old Mar 24, 2014 | 08:21 AM
FLA996TT's Avatar
I have a charger/maintainer that I bought and it has an adapter to go into the cigarette lighter so I'm going to hook that up when I do the swap. Right now I'm researching batteries.
Old Mar 25, 2014 | 04:14 AM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
I used the Bosch Premium Power, 36 month free replacement, / 96 month Pro Rate Warranty. Part number 49-850B. Group size 49. SKU #:9073755.
CCA @ 0°F: 850.
CA @ 32°: 1000
RC Mins #@ 25 amps: 120
Old Mar 25, 2014 | 07:10 AM
sjg1138's Avatar
sjg1138 is infamous around these partssjg1138 is infamous around these parts
For the radio code you can try this. worked for me.
http://www.a2dvoices.com/realitycheck/porsche/
Old Mar 25, 2014 | 07:37 AM
FLA996TT's Avatar
I have a maintainer on it now to hold the code and will keep it on through the process, uses the lighter port. Thanks.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
ModBargains
997 Vendor Classifieds
Oct 13, 2015 03:53 PM
ModBargains
996 Turbo Vendor Classifieds
Oct 13, 2015 03:52 PM
