Keeping oil level high help lube IMS?
Does keeping the oil level high help lube the IMS? Does the oil level get that high under normal idle and driving conditions? I also have a theory about the outer race failing on the IMS, is it due to idling and low rpm-ing the car? My theory is that the unloading bearing bangs around unloading and loading smacking the outer race. I'm am totally just guessing from what I have read about the failures.
Problem is the bearing is sealed. Oil level will do nothing for it. IIRC the theory is the bearing grease/lube will leak out over time causing the bearing to dry out. Then lead to failure. There is very little engine oil that will seep back in.
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
