Startup + 60 secs noise normal on 911?
Old Jan 20, 2015 | 09:43 PM
blackonblack996's Avatar
blackonblack996 is infamous around these parts
Thx in advance. I was previously a brand new Cayman 2007 driver, but then switched to a more classic 996 C4. (Yes, I like the 911 better!) My 996 has a noise upon startup and need to know if abnormal. It's on just for startup + 60-80 seconds. Sounds electronic + mechanical, high pitch/very high frequency metallic grinding - perhaps a pump of some sort? It's under the motor hood. Is this normal and does anyone know what it might be? I have no other symptoms...just want to get ahead of a failure of some kind if abnormal.
Old Jan 21, 2015 | 07:37 AM
robbieracer's Avatar
robbieracer is infamous around these parts
It could be the SAI (secondary air pump). It's emission related and runs for a couple minutes after start up. It sits in the left side of the engine bay, just in front of the left rear lights. Maybe it's starting to go out if you have a high pitched whine.
Old Jan 22, 2015 | 10:37 AM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
My '99 C2 does the same thing. It sounds like a fan or turbine for about 90 seconds after starting when cold. Once the engine is warmed up it's not there. It has never given me any problems. I use the noise as my cue for letting the engine warm up before I drive.
Old Jan 22, 2015 | 11:01 AM
dporto's Avatar
dporto is infamous around these parts
"It could be the SAI (secondary air pump). It's emission related and runs for a couple minutes after start up."
^This^ is a pretty good bet. This being said, while fairly common, it shouldn't be considered "normal". Apparently it's a pretty simply DIY to remove the pump, take it apart, lubricate the bearings (they get dry which is what leads to the noise) put it back together and reinstall. Do a search here, on Rennlist and Renntech (I don't remember where I read it, but I know it's somewhere) Good luck
Old Jan 22, 2015 | 11:03 AM
Good to know it can be serviced/lubed. I figured it would need to be replaced. Thanks!
Old Jan 22, 2015 | 11:07 AM
dporto's Avatar
Yeah, I don't know if you could get a shop to do it (or if it would be cost effective) but if you're up for the challenge, you can probably save a few bucks...
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Feelgood MD
Mar 24, 2016 09:35 AM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
Saint Ari
Sep 4, 2015 03:30 PM
