Durametric v6 enthusiast wont talk to abs and air con modules
Hey there
I have a 98 C2 and I bought the Durametric Enthusiasts kit but cannot get it to connect to the a/c or abs systems. Having looked at the schematics I can see that the alarm and engine share the same bus and this connects fine with a green LED on the tool. However when I attempt to connect to the others the tool alternates between red and green And won't connect. I know the brakes and the a/c share the same bus. Durametric suggested a short but have checked continuity to ground and it is fine. No short and is showing 2.5v which is healthy for CAN systems I am familiar with.
Any ideas or similar experience.
Regards
Steve
Regards
Steve
I have heard a lot of things go thru the cluster and sometimes the cluster needs to be reset. On my 2005 987s tip it wouldn't connect to the tip. Version 5 connected fine. Can also try to connect straight to the module instead of picking the car.
I have tried versions 5 and 6 now. Attempted connecting to the a/c with the fuse pulled on the abs and visa versa just in case either one was causing the issue. How did you reset the dash?
Cheers
Steve
Cheers
Steve
carwash
Sep 26, 2015 03:11 PM
hacellular
Aug 31, 2015 08:34 AM
