Throttle Body Flap 996.2
Old May 1, 2015 | 01:29 AM
carrera4slakem's Avatar
carrera4slakem is infamous around these parts
I'm trying to cure a flashing CEL. I replaced all the coil packs with no success. I keep getting a misfire in cyl 1 but it runs so rough I shut the engine off after no more then like 20 seconds so the misfires could be going to the other cylinders if I tried to let it run any longer.
I was looking at the throttle body and noticed the flap is open about a 2-3mm. If I push down on the flap it will close all the way and when I let go it opens back up to the 2-3mm open position.
Could the throttle body not being the fully closed position cause a misfire?
Old May 1, 2015 | 07:21 AM
alpine003's Avatar
No this normal the last time I checked. You have a eGas tb so it would've compensated anyways. I would pull the cel codes and go from there.
If you recently installed coils yourself, make sure you triple check your connections at the connectors. These don't like to seat themselves all the time. You need to verify you hear a click when pushing in the connectors.
Old May 1, 2015 | 06:55 PM
sjg1138's Avatar
sjg1138 is infamous around these partssjg1138 is infamous around these parts
Did you replace the plugs as well? What did the old ones look like?
Feelgood MD
Mar 24, 2016 09:35 AM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
maroli
Sep 15, 2015 07:07 PM
austenkuek
New Member Introductions
Sep 10, 2015 10:45 AM
andbos
Sep 7, 2015 07:13 PM
