tarrett engineering front monoball camber plate help
I bought these, and they are installed on my 996; first its a nice product. They fit fine etc. But, they set the front very aggressive for street use with negative camber; which I know it says -1 degree camber or more....does anyone know or have experience with if these can be set up just a bit more neutral for more friendly road use?
FYI I blew the hell out of my inner tires 360 degrees down to the belts partially due to the camber, partially I was pushing the car hard...so just looking to get a more neutral setup...don't want to go back to stock but if I have to I guess I can swap.
thanks
http://www.tarett.com/items/996-997-...smt-detail.htm
thanks
Lol, -1deg is nothing and hardly what I consider aggressive. Once you go below -2deg is where you may run into possible issues. Just make sure to get a good alignment with proper toe settings and enjoy the extra turn in response.
Just curious why you bought monoball mounts in the first place if you weren't looking for a sporty ride?
Since you want justification I bought the camber plates because the rubber wears out on the factory mounts and the camber plates are metal second I was under the impression I could ride at a -1° camber which apparently is not true hence my question. When I bought these the website was a bit vague as to the camber adjustment range and it still is. But again if you don't know the answer fine hopefully does. I am going to call them anyway just wanted user experience
Wow................
first you didn't help me at all but it's an extra -1° on top of factory or more in my ride right now sits at -2.5°
since you want justification i bought the camber plates because the rubber wears out on the factory mounts and the camber plates are metal second i was under the impression i could ride at a -1° camber which apparently is not true hence my question. When i bought these the website was a bit vague as to the camber adjustment range and it still is. But again if you don't know the answer fine hopefully does. I am going to call them anyway just wanted user experience
First you didn't help me at all but it's an extra -1° on top of factory or more in my ride right now sits at -2.5°
By your logic, why not get solid engine mounts too since you don't have to worry about rubber wearing out there too?
To be helpful, your best bet is to get new stock mounts. Rubber exist in quite a few places for comfort and nvh control on a street car. I see many peeps trying to out engineer the factory when it comes to a normal street car which often ends in less than desireable results. Building race or track cars are the exception.
Lol, wow is right. You never specified being -2.5 deg down. Be a bit more specific if you want the best responses.
Yes I should have been more specific about my camber setup. I have not been able to call tarret yet
I love the monoballs...they rock. My ride is better than stock even with H&R lowering springs and bilstein sport schocks + monoball. This is just as simple as getting better wear on tires....
What are your settings on your front toe? Toe shreds tires more than camber but they go mutually hand in hand. List your toe settings.
Let me see if I can find the toe numbers. As a matter of course, I think the guy tried to set the alignment up as close to stock as he could...other than the 2.5 deg camber...
However, if with negative camber, I need to be on one side of the toe range vs the other, vs in the middle, it would be helpful to know that so I can get them to set it up that way?
Okay, I had mine aligned and asked for this, in the rear I ask for neutral toe and just a small amount of negative camber, the rears sit pretty flat but you can see a tad negative camber, them on the fronts I asked to set to compliment the rear settings. I'm at 8500k on them and still have plenty of tread. The "toe out" really destroys the tread.
Do you know what stock is?
If you have neutral toe, that's what I would keep it at. Swaying further from the manufacturer's settings will take away some character and may no longer feel like a Porsche.
Since it's been awhile, I suggest taking it in to get the alignment checked at a real good place. Some of them don't charge you just for checking it. It's better to spend the hundred or so on a real good alignment vs having to replace tires often.
Toe is tied to camber and can only be adjusted so far depending on your camber settings.
What does your other suspension pieces comprise of and what brand/model tires have you been using?
Tires...in the front were michelin pilots. I went cheap this time with a set of Kuhmos....but actually I like them.
The alignment was done last year. I will bring it in to do that, make sure the toes are neutral on front and rear etc....This time I will bring it to a different spot just incase....
04-28-2022 12:38 AM
ECS Tuning - VW
08-19-2015 08:58 AM
