AC Control Setting
Old Sep 20, 2015 | 10:54 AM
SMKaz's Avatar
SMKaz is infamous around these parts
AC Control Setting
Have a 1999 C4 - when I set the AC setting on Low I have plenty of cold air, however as soon as I try to make it a little less cold by moving up one notch I get hot air as if the heater is on - previously I'm quite certain that I was able to control the temperature of the cold air without going directly to hot air - any suggestions? Thank you in advance.
Old Sep 20, 2015 | 04:21 PM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
Something like that happened on my BMW when the ambient air temp sensor was damaged. Perhaps check that?
Old Sep 20, 2015 | 05:42 PM
SMKaz's Avatar
I'll take a look at the sensor - thanks for your input.
Old Sep 22, 2015 | 02:52 PM
996_717's Avatar
996_717 is infamous around these parts
have the same issue with my 1999.....BUT my ambient air sensor, which i believe is mounted in the front of the car in the grille down low....seems to read OAT and display correctly on the dash.
would like to see if you have a fix for this.
Old Sep 22, 2015 | 05:12 PM
SMKaz's Avatar
I was just about to go see what my INDY shop had to say about it and it starts working flawlessly - will have to see how long this lasts. I'm not a fan of intermittent issues - OCD and all.....
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
