Need help, what are these wheel centers called
Old Dec 30, 2015 | 02:38 PM
Fieldsport's Avatar
Fieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to beholdFieldsport is a splendid one to behold
Question Need help, what are these wheel centers called
Need help, what are these wheel centers called, I would like to see if they make some to fit some Cargraphic 3 piece wheels I just purchased.
TY
Old Dec 30, 2015 | 05:07 PM
pmkazz's Avatar
pmkazz is infamous around these partspmkazz is infamous around these parts
Cargraphic makes them. Contact them directly.
TY
Old Dec 30, 2015 | 06:58 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
imitation center caps...they are a little heavy though.
Fit's most aftermarket wheels....they don't fit stock ones...
I used them for a while and sitting on the shelf somewhere now
Old Dec 30, 2015 | 07:52 PM
Fieldsport's Avatar
Thats what I thought they would be called but could not find any
Going on this car:
I am going to have centers painted color match, but wanted something a like those fake center lugs, wheels are 3 piece cargraphic
What brand did you have?
Old Dec 31, 2015 | 10:48 PM
geetee's Avatar
I'm pretty sure they're all the same. Even cargraphic one's aren't made by them. Mine looks just like the one's posted above.
It's a 4 piece with the removable red pin. It did look good on the car...
Old Dec 31, 2015 | 10:52 PM
geetee's Avatar
Old Jan 1, 2016 | 08:53 AM
Fieldsport's Avatar
darn, could not open file, are they plastic or aluminum?
how do they attach, is it just a snap fit or some kind of expansion lock going into center of wheel?
BTW, thanks for your input
Old Jan 1, 2016 | 09:56 AM
geetee's Avatar
alum. Can be separated to be painted
a bolt holds 2 plates together. One plate goes on the inside and the outside plate is what you see in picture with the red pin.
Old Jan 21, 2016 | 01:19 PM
turbogts's Avatar
turbogts is infamous around these parts
http://www.rennline.com/Rennline-Whe...oductinfo/W01/
$175.00 a set of 4 i have these on my 996 GT3 and 996C4. these are a three piece metal center cap.
Old Jan 21, 2016 | 02:07 PM
Fieldsport's Avatar
Perfect, ty
What are the little screws around the center, are they fake?
Old Jan 22, 2016 | 11:10 AM
turbogts's Avatar
no the three screw are real. every pat on theses caps is real and they completely dis-assemble very easy if you want to paint a different color.
Old Jan 22, 2016 | 01:39 PM
Fieldsport's Avatar
You don't have to drill wheels do you?
Or are they contained in the center cap?
Old Jan 22, 2016 | 03:28 PM
turbogts's Avatar
no dont drill anything. take off wheel, takeout old center cap, hold base ring from front, backing ring from back side, center nut from front though back part hold everything together, screw center to tight, done repeat each wheel..
Old Jan 22, 2016 | 06:33 PM
Fieldsport's Avatar
Sounds good
Ty again
Old Jan 23, 2016 | 11:12 AM
turbogts's Avatar
wheel centers
here is a photo of what these centers look like.
Name:	lg aug 2015 photos 097.jpg
ID:	438140   Click image for larger version
Name:	September 2014 944 GT3 curent photos 027.JPG
